Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Motorcraft replacement vs original part
Old Sep 11, 2002 | 11:37 AM
Avanti's Avatar
Avanti
Is there a way to tell the difference between & original installed part ie fuel pump and later Motorcraft replacement? Is there a diff in markings or numbers? I am trying to ascertain if my fuel pump has been replaced. I have 163 K miles & the pump says genuine Ford part. If it has not been replace it is due. Do not want it failing at 0 degrees in a blizzard.
Old Sep 11, 2002 | 03:52 PM
otto's Avatar
otto
[updated:LAST EDITED ON 11-Sep-02 AT 04:53 PM (EST)]I really dont know if they use a dealer part, but maybe did the older original fuel have metal tag screwed down on them or was that only carberators
Also you might try looking for gasket sealer that might not be factory, or even look at the bolt heads and maybe see if they are a little rounded off or anything might indicate someone had their fingers in it
Old Sep 11, 2002 | 07:57 PM
theonlybull's Avatar
theonlybull
the last fuel pump i bought was only $40 canadian.. so if your worried about it, put a new one on it and be sure that it's gonna work.
Old Sep 11, 2002 | 08:45 PM
Torque1st's Avatar
Torque1st
Posting Legend
This is a good question for anybody restoring a vehicle. Just how do you tell if it is an original part, OEM replacement, or aftermarket?
Old Sep 11, 2002 | 09:01 PM
otto's Avatar
otto
Post Motorcraft replacement vs original part
didnt ford use an outside supplier latter in the 70 and early 80 instead of autolite for carbs and fuel pumps, i know my 300-6 had carter and all the 351w H.O. 4V i have seen used holleys
Old Sep 13, 2002 | 10:30 AM
vettehauler's Avatar
vettehauler
wtroger
1983 - 2012 Ranger & B-Series
27
Oct 10, 2017 10:09 PM
Tom
Feb 6, 2016 01:19 PM
KhanTyranitar
Aerostar
Jul 12, 2014 09:51 PM
dawhits1
Jun 11, 2014 05:53 AM
