Sponsored by: Auxito
p1506 code
Old Mar 6, 2006 | 10:14 PM
rodgers40's Avatar
rodgers40
Cool p1506 code
i have a 97 f150 thats about to drive me crazy,check engine light on and had it scaned and showed p1506 this has been going on since nov. last year have replaced ever senser on the thing and replaced the vacaum line going to the back of the intake what ever it is it causes the transmission to act up to. thanks for any help!
Old Mar 7, 2006 | 06:55 AM
projectSHO89's Avatar
projectSHO89
Good job throwing parts at the engine.
Did you ever look up the failure code and follow the troubleshooting directions?
Exactly which sensors did you replace? It is unlikely you replaced "every" one of them. List them by name.
Describe any symptoms besides that it's "making you crazy".
Steve
Old Mar 7, 2006 | 08:49 AM
Administrater's Avatar
Administrater
"Throwing parts at the engine"... LOL.... LMAO... Wait til it starts throwing them back at you.. Mine does. :P
That's why I only work on mine at night. That way the neighbors don't notice.
I love this board.
Old Mar 7, 2006 | 09:15 AM
please's Avatar
please
You may already know but that code is for iac valve over speed error. Did you replace your iac valve already.
Old Mar 7, 2006 | 07:10 PM
rodgers40's Avatar
rodgers40
thanks for the replys, i have replaced the iac,maf,ecu,o2,speed control,and others that i can't think of.and after replaceing them it runs fine for a day or two and right back to the same thing bad gas milage trans. don't shift right.
Old Mar 7, 2006 | 08:44 PM
coldairintake's Avatar
coldairintake
How about taking it in for a scan?
All the $$$$ you spent on throwing parts on it could have paid for a scan and repair.
You must get a Christmas card from your parts guy!
Old Mar 8, 2006 | 07:05 AM
rodgers40's Avatar
rodgers40
i did have it scaned ,that's why i replaced all of these parts it was not all at one time this has been since nov., i would replace what ever the scan said.
Old Mar 8, 2006 | 11:55 AM
gui88ford's Avatar
gui88ford
sounds like someone is "scaning" their way into your wallet
Old Mar 8, 2006 | 01:09 PM
projectSHO89
:shaking head and rolling eyes....
Geez, just take it to a mechanic who knows what he's doing and have it fixed...
Steve
Old Mar 8, 2006 | 01:26 PM
gui88ford's Avatar
gui88ford
novel idea....
Old Mar 8, 2006 | 04:42 PM
ryans428's Avatar
ryans428
You might want to check your pcv valve because the pcm is calibrated to a certain amount of flow around the iac and throttle body so that the iac valve duty cycle at idle is around 30% at idle, so I would look at things like your pcv valve being clogged, and if your throttle body has lots of gook around it and the butterfly or in the drilled holes, it will cause the pcm to drive the duty cycle up to about 45-50%, or more, so that it will idle properly. This code will usually only be set in the older obdII vehicles, also if you don't change your oil regularly it will help to clogg up your pcv system, seen it before, will see it again. Oh yeah, when you were throwing your wallet, and parts, at this thing did you have a helmet on incase it chunked something back?
-Ryan
goatsauce
Escape & Escape Hybrid
Jan 17, 2017 07:15 AM
Whitey Ford
Mar 23, 2016 03:59 PM
pleshdog21
1997 - 2003 F150
Sep 10, 2013 06:42 AM
matt_sti
1983 - 2012 Ranger & B-Series
Apr 13, 2012 09:55 PM
pfpost
1997 - 2003 F150
Aug 10, 2011 01:19 PM
