Sponsored by: Real Truck
how do you.....
Old Mar 6, 2006 | 09:55 PM
ajordan193's Avatar
ajordan193
how do you.....
take off the steering column cover with the shifter and boot? My overdrive cancel switch isn't working so i'm going to see if the wires are frayed. Thanks
-Andrew
Old Mar 7, 2006 | 10:45 AM
EnviroCon's Avatar
EnviroCon
Unscrew the tilt lever. Look up underneath the steering column cover, there are 4 holes, but only 3 contain screws. Remove the 3 screws. You can now just seperate the two halves of the steering column cover and remove them.
