Sponsored by: Real Truck
Remove rear view mirror
Old Mar 3, 2006 | 11:28 PM
papa737's Avatar
papa737
Does any one know how to remove the rear view mirror on a 2004 F250 XLT. I can't see how it is removed. I don't want to crack my windshield.
Old Mar 4, 2006 | 07:44 AM
RAMBOv10's Avatar
RAMBOv10
On a 2002 the manual says:
"With the mirror rotated to the vertical, pull downward until the mirror releases"
I dont know if a 2004 is the same or not. And I have not tried this on my truck, just passing on the info in the manual.
Daniel
Old Mar 4, 2006 | 08:36 AM
papa737's Avatar
papa737
No that didn't do it. thanks. I will go by a glass shop today and see if they can get it off.
Old Mar 7, 2006 | 08:03 AM
RCKYMTN-PSD's Avatar
RCKYMTN-PSD
Just pull down hard on it, you should see the clip start to spread off the bracket - try to pull down close to the part that attatches to the bracket so you dont pull the mirror apart. Then you have to push down hard to re-attach it until it clicks back on the bracket otherwise it will rattle around.
Old Mar 7, 2006 | 11:42 AM
papa737's Avatar
papa737
Thanks; That did the trick. I was afraid to pull down to hard.
