Powder coating
Old Feb 24, 2001 | 10:57 PM
blaxuede's Avatar
blaxuede
Powder coating
Old Feb 25, 2001 | 07:28 AM
tra's Avatar
tra
Powder coating
Can you powder coat headers to kepp them from rusting or tarnishing in color. Thanks
Old Feb 25, 2001 | 10:55 AM
bushman's Avatar
bushman
Powder coating
No you can not powdercoat headers because the plastice powder that is used melts at about 400 degree's. But there is a process called ceramic coating that can be done on your headers. This process will make your headers virtually rustproof, hold the heat inside the header where it is supposed to be, and you can have it done in a large variety of colors. I had mine done in the chrome color and it really turned out shiny.
67 F250 MudBogger
70 bronco
73 F250 crewcab
75 F350 crewcab longbox
79 F250 crewcab 4wd
Bushman
Old Feb 25, 2001 | 11:41 AM
77_F150_4x4's Avatar
77_F150_4x4
Powder coating
You can buy them already ceramic coated too. I should have done that with mine they are starting to rust. Flow Tech sells them ceramic coated for the FE, M-block, 302 but they are a pain to put on.
Curtis
77_F150_4x4 aka
"The BeAsT"
