94 oil pressure
Old Mar 6, 2006 | 04:22 PM
ssg354's Avatar
ssg354
94 oil pressure
I have a 94 f-150 w/ 5.0. One day oil pressure just dropped. Pressure fine at idle, but when revs a bit pressure drops out. engine isn't knocking when pressure goes out. any history of this out there? just want to do a pump to find it's something else
Old Mar 6, 2006 | 04:44 PM
quicklook2's Avatar
quicklook2
you need to check the engine with a mechanical gauge.
the stock one drops if pressure is less than 7 pounds, it is really just an idiot light in drag.
Old Mar 7, 2006 | 05:45 AM
ssg354's Avatar
ssg354
Forgot to put in that I did hook up a mechanical gage, still dropping off. I'm wondering about the relief valve.
Old Mar 7, 2006 | 07:32 AM
ssg354's Avatar
ssg354
what is the minimum pressure safe to run?
Old Mar 7, 2006 | 09:20 AM
quicklook2's Avatar
quicklook2
my 4.9 had the pickup screen almost completely blocked.
i always got nervous in any car that was around 15 pounds, but i do not know exactly.
try running some cleaner or seafoam.
Old Mar 7, 2006 | 02:58 PM
ssg354's Avatar
ssg354
Thanks, I'm going to try pulling the distributor and checking the shaft. If they look ok I'll run the pump with a drill. Might get some info from that. Thanks again.
