97 Explorer - Shifter issue
Old Mar 6, 2006 | 01:15 PM
Allan97Explorer's Avatar
Allan97Explorer
I have a 97 Explorer (Eddie Bauer). Today I could not move the reverse/neutral/drive shifter out of park (I did have my foot on the brake).
It was locked out, I messed around with it (since I wasn't going anywhere) and found that if I put the ignition switch to the position before the starter is engaged, I could put the shifter into neutral and start my Explorer. From there, I could put it into drive or reverse.
The problem continues to be from park, the explorer will still not engage into reverser/neurtral/drive if I have the shifter in park, my foot on the brake, and the car running.
It appears to be a linkage issue? I am no backyard mechanic, but if anyone else has had a similiar issue or knows of this, I would appreciate some assistance on why it is happenning, and what I can do about it without taking it into the shop.
Old Mar 7, 2006 | 01:56 AM
87 XLT's Avatar
87 XLT
If the brake lights are not working it wont shift, and you need to check interior fuse 13 & the brake light switch.
If the brake lights are working, check interior fuse 10.
If fuse 10 is OK, the shift lock actuator is probably shot.
Old Mar 7, 2006 | 05:28 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Allan to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
