tire size question
Old Mar 6, 2006 | 11:37 AM
Fordman79's Avatar
Fordman79
Question tire size question
On my 79 right now I have 235/75/R15, I have found some 33'' tall tires with rims for cheap. I have stock gearing in the axles and i was wondering if moving to this size tire would help me with getting a little better mileage out of my truck. I know the difference in size will affect my speedometer ( it is already 10 mph off) it says I'm going faster than I actually am going. will the bigger tire help that too or make it worse? Would 31" work better?
Old Mar 6, 2006 | 01:06 PM
460's Avatar
460
I have found that going to a larger tire while keeping the same gears usually gets worse MPG. There is more rotating mass and you're engine will have to work harder to move the truck. It will help fix the speedo though.
Old Mar 6, 2006 | 02:03 PM
Mil1ion's Avatar
Mil1ion
Did you measure the height of the 235's ?
Old Mar 6, 2006 | 05:02 PM
MBBFord's Avatar
MBBFord
235/75/R15 are about 29" tall, my old set was the same size.
If your gear ratio is off by 10 mph with stock tires, then you might have 4.10 gears already installed, and then 33" tires would help your gas mileage on the highway alot, while bringing down the RPMs.
Is your truck 2wd or 4wd?
Old Mar 6, 2006 | 06:03 PM
busted knuckle's Avatar
busted knuckle
higway yes better mpg. i have 35s on mine with 3.55 for now will go to 4.56 this summer. dont expect good mileage from her in town.
Old Mar 6, 2006 | 07:20 PM
MBBFord's Avatar
MBBFord
He did say his speedo is off by about 10 mph, so that usually happens when you go with a higher(numatically gear ratio) and stay with stock tires. So he might be running 29" tires w/4.10 gears and the 33" tires would help increase gas milage.
Old Mar 6, 2006 | 09:53 PM
petes79f150's Avatar
petes79f150
How can you figure gas mileage? If the speedo is off, so is the odometer.
Old Mar 6, 2006 | 10:49 PM
MBBFord's Avatar
MBBFord
Yep, the odometer would be off too. My truck shows a extra mile for about every 10 miles I go, so the gas mileage will be alittle off too.
Old Mar 7, 2006 | 12:00 AM
Mil1ion's Avatar
Mil1ion
Larger/taller tires revolve slower than smaller/shorter tires.
This will will show on the speedo as going slower then you really are and register
less mileage than you have actually gone.
Old Mar 7, 2006 | 12:05 AM
Bdox's Avatar
Bdox
There is a selection of speedo drive gears to choose from to correct the speedo reading.
Old Mar 7, 2006 | 11:34 AM
Fordman79's Avatar
Fordman79
It won't hurt the odometer because it quite working a couple of years ago. I had to replace the rear end gear set back in 2001 and if i remember correctly the ratio is 3.55 I drive about 40 miles round trip to work 4 days a week and about 30-35 on the weekend. I use a little less than a 1/4 tank per day. Oh and it is 4x4.
Old Mar 7, 2006 | 05:19 PM
MBBFord's Avatar
MBBFord
If it has 3.55 then 33s won't hurt anything to much, but you won't have as good accleration off the start and you'll get a little less gas mileage in town.
33s would look good and fill in the wheel wells nice on a 1/2 ton 4x4.
Old Mar 7, 2006 | 06:40 PM
Jmudder79's Avatar
Jmudder79
Who sells them? I've been thinking about fixing mine, but don't know where to look for 'em.
Old Mar 7, 2006 | 06:51 PM
MBBFord's Avatar
MBBFord
Go to broncegraveyard.com, they have a little calculation to figure out what exactally which one you need too.
Old Mar 7, 2006 | 06:53 PM
Jmudder79's Avatar
Jmudder79
Thanks MBBFord. That was quick.
