tire size question
Old Mar 7, 2006 | 07:38 PM
likethefords's Avatar
likethefords
I have 33'' tires on my 78 and still have the 3.55 s in there and it looks nice and has plenty of power. Mileage isn't to horrible either.
Old Mar 7, 2006 | 07:55 PM
Bdox's Avatar
Bdox
Originally Posted by MBBFord
Go to broncegraveyard.com, they have a little calculation to figure out what exactally which one you need too.
Ford dealers too.
Old Mar 7, 2006 | 08:34 PM
keithredfirebird's Avatar
keithredfirebird
Here is a great site that will show what the tire size is
http://www.rgp.nl/bird/misc/wielen.htm
Old Mar 7, 2006 | 08:39 PM
MBBFord's Avatar
MBBFord
Wink
I know it wouldn't be bad, but if you had 31s then you would have better take off, and better gas mileage(not alot, but it'd still be better).
I have 37s on stock 3.50 gears, and it sucks for acceleration and MPG, but almost got enough to regear now.
Old Mar 7, 2006 | 10:47 PM
1979FordF-250's Avatar
1979FordF-250
Talking go 33's
with the 33's your highway mpg would increase because of the lower rpm, but your city would get worse because the engine would have to work harder to move the rig. your speedo would also be mostly corrected. You might even want to consider some new 4.10 gears.
Old Mar 7, 2006 | 10:57 PM
likethefords
I hope to eventually get 4.10s, but on a limited budget right now and its doing fine as is, so it'll be awhile
Old Mar 9, 2006 | 10:40 AM
Fordman79's Avatar
Fordman79
Thanks for all the help on this. I think I'll go ahead and use them. I tried one on just to see how it looked and your right they do fill out the wheel wells nice.
Old Mar 9, 2006 | 01:34 PM
jad4's Avatar
jad4
a good way to check how fast you are going is to use a gps. You can have someone in the passenger seat writing down what your speedo says vs what the gps says(you can't get more precise than that) and then you could put a sticker or something on your speedometer that would remind you how fast you are going.
Old Mar 9, 2006 | 02:25 PM
Mil1ion's Avatar
Mil1ion
Old Mar 13, 2006 | 11:12 AM
Fordman79's Avatar
Fordman79
I was going to do that again when I get the tires put on. I did it once with the 29" tires to check how off it was. Thanks again.
