fe torque sequence
Old Mar 6, 2006 | 06:57 AM
novadragman2005's Avatar
novadragman2005
fe torque sequence
I have all the numbers to torque down my motor, but I do not know what sequence to do it in, can anyone help me with this info for my mains, cylinder heads, intake, rocker arms, etc, please help need this info yesterday, thank you.
Old Mar 6, 2006 | 07:09 AM
novadragman2005
ps its a 360 motor if its different from the other fe motors, thanks
Old Mar 6, 2006 | 09:11 AM
fordeverpower's Avatar
fordeverpower
For the mains, try the 3rd cap first then work out in a circle.
Heads viewed like:
9 5 1 3 7
10 6 2 4 8
You start at 1 which is the middle top bolt of the head, both heads are torqued the same.
The intake:
Back 4 7 1 9 6 front of intake
5 10 2 8 3
The rockerarms are tightened a couple of turns, then the next bolt. Its slow process but if you tightened one bolt at a time, the shaft can BEND!
California Codfish
Sep 19, 2023 04:08 PM
beersy50
Aug 24, 2010 10:12 AM
kenpobuck
29
Jan 26, 2010 11:34 AM
rustyolred27
Apr 26, 2009 05:53 PM
offroadtruck
Mar 11, 2003 10:26 AM
