390 Redline???
Old Mar 6, 2006 | 02:22 AM
f250rangerexplorer's Avatar
f250rangerexplorer
390 Redline???
Does anybody know where the 390 redlines from the factory???? how about with stock heads, and a mild build??? Would it change any....? Thanks guys i'm just leanring about the FE engines so help me out here.... got the 400's down but these are a new game to play with.
I'm thinking about 5500 but not sure....
Old Mar 6, 2006 | 02:31 AM
gtex's Avatar
gtex
5500 is a good number for a mostly stock 390. generally, they will run out of breath before then, depending on your carb/intake/head confiuration. As for the valve train, 5000-5500 is probably a good cut-off assuming it's in good shape.
Old Mar 6, 2006 | 02:35 AM
ford390gashog's Avatar
ford390gashog
yeah i would say about 5000 rpm. those stock non adjustables are what will get you. but as stated it is hard to turn a stocker past 4500 it simply runs out of air.
Old Mar 6, 2006 | 06:21 AM
76 F-150 390FE's Avatar
76 F-150 390FE
i have pushed mine to 5500 simply becuase that is where my transmission shifts when my foot is to the floor, and it is bone stock with a holley 4160 600 cfm and D2TE-AA heads.
Old Mar 6, 2006 | 09:23 AM
Torque1st's Avatar
Torque1st
Posting Legend
Stock my 390 turned about 4500 but after I was thru building it I could turn 9000 so they can be built right! -Have fun!
fordeverpower's Avatar
fordeverpower
looks like 50-5500 rpm is a redline range. With stock springs i would lean toward 5000rpm.
Old Mar 6, 2006 | 11:47 AM
fordraceboy's Avatar
fordraceboy
i vote for 5000 on a bone stock setup... a cam and good springs will get you to 5500-5800... reliability starts becoming a factor in any motor when you push 6000 or more for very long with stock parts.. JMO
Old Nov 13, 2013 | 09:46 PM
Ford 67 Ford's Avatar
Ford 67 Ford
Old thread but good to know. Guess I've been taking it easy with a 4100rpm pill in there, don't know that I want to go over 5000 but I'll do 4500 for now. Later.
Old Nov 14, 2013 | 09:33 AM
MIKES 68 F100's Avatar
MIKES 68 F100
Stock
5000 is where they stop making power so no use reving higher .
Old Nov 14, 2013 | 10:42 AM
Ford 67 Ford
Not all stock but not a big build either. When I had it rebuilt years ago this is what I did. 390 w/ RV cam, 4 bbl Holley, Cobrajet intake, Thorley headers, Flowmasters, MSD box, stock heads, stock distri., not balanced. So little more than stock but that's it. Later.
Old Nov 14, 2013 | 11:05 AM
MIKES 68 F100
My 390 (see sig) 5300 rpm is about where she tops off , but i built the motor for more TQ then HP
takehikes
Aug 8, 2015 08:49 PM
Army RET
Modular V10 (6.8l)
15
Feb 15, 2015 01:24 PM
topscrt
Modular V10 (6.8l)
Sep 8, 2013 02:03 PM
abranz
Dec 3, 2012 08:54 PM
rb76543
Jun 26, 2010 06:23 PM
