tilt hood:
Old Feb 28, 2001 | 12:32 AM
rusty79's Avatar
rusty79
tilt hood:
Old Feb 28, 2001 | 02:19 AM
clizer's Avatar
clizer
tilt hood:
I have a 1976 ford 4x4 f-150. 7"'s of lift. I want to install a tilt hood.(the front clip). What am I getting in to? If I can locate a hydraulic lift and necesary parts, can I use the hood thats on it? Money wise, how much would it cost?
Old Feb 28, 2001 | 07:39 AM
FE427TP's Avatar
FE427TP
tilt hood:
http://www.usbodysource.com has fiberglass tilt hoods, that'll save you some weight
Old Feb 28, 2001 | 08:40 AM
etobolski's Avatar
etobolski
tilt hood:
You can just use the stock parts and make your own. I did this on mine, and the only parts I needed to buy were some supports for the small portion of the inner fenders that holds the hinges, and a shock to help keep the hood open. This method is a lot cheaper than the $1000 fiberglass noses, and works just as well. Good luck.
Eric Tobolski
Aerostar
Aug 21, 2024 11:23 PM
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Mar 11, 2001 10:13 PM
