We have a 1990 Aerostar ext with a 4.0 litre. My bandmates and I plan on going on an across Canada tour with it in June. We would like to take a small travel trailer along with us. With us, all of our gear, plus the tongue weight of our trailer, we will be putting a considerable load on the rear coil springs. I'm thinking of selling it and getting a fullsize van because of this. I would rather not though due to the fact that I know the van is mechanically in really good shape and would stand up to those kind of miles. Does anybody have a suggestion. Can you get some really heavy duty springs for these? Thanks.
You can get cargo springs from Ford, they run around $200 a piece, but it would still be cheaper than buying a different used van that you would have to dump money into.
Also you are going to want to put on a sway bar and maybe go with Air shocks or Air bags to help keep you level. Do a search and you will find many posts discussing each.
Uhm, disregard that remark, this guy doesn't respect these things. Besides, an Aerostar with a proper suspension will ride better than a cargo van, believe me I know. I have one.
Can you add up the towing weight? People, trailer and equipment. The Aero has a rated towing capacity that you should be able to help you decide. You don't want to burn up the tranny.
I dont know why, but there was a tranny cooler on my van ('89). I removed it when I swapped a tranny, but it was installed near the stabilizer bar. About rear spring, I've replased it and I use springs of mercedes w123, but havy duty springs requires other shcoks!
The van came with a great big tranny cooler from the factory, so that is taken care of. Does anyone know the approximate price it is for air shocks and springs? Also what kind of job is it to do?
A cargo van wouldnt be much heavier than an aerostar full of gear. First of the gear in and of itself is pretty heavy. Also remember that cargo van's are pretty stripped down to basics, unlike our "luxurious" (options add weight, i'll remind you) people-pushers. The cost and effort of adding beefier springs, sway bars, tranmission coolers and the like would probably about equal the cost of renting a brand-new cargo van. If this is going to be a one time thing. Let's face facts though, Aerostars were built to carry people, not cargo.
If there are just four people, how about removing the center seats, and move the back bench to the center? That will save about 80 pounds of weight and give you a ton of space in the back for gear, so you may not need a trailer. Two guys in the back should be able to sit comfortably on a bench seat made for three.
That's the plan. The trailer is not going to be used for gear because it's a travel trailer. We're using that to sleep in. All the gear will be going into the back of the van.
