Sponsored by: Auxito
Engine running rough, possible misfire?
Old Mar 5, 2006 | 08:33 PM
richard stone's Avatar
richard stone
I have a 2000 5.4L. Yesterday while driving, the motor just started running rough. Thought it might be water in the fuel so I put in some dryer, filled the tank, but still did not solve the problem. The check engine light is both flashing and staying on. If I drive it over 40mph it really shakes and vibrates. My oil and tranny fluid are both clean, no signs of water in them. No other problems other than it running very rough. Has anyone had this problem before??
Old Mar 5, 2006 | 09:04 PM
AlfredB1979's Avatar
AlfredB1979
Check for codes.
The CE light is on, you have symptoms, you'll have a code in all llikelihood.
Get the numbers, come back to us with said code numbers, we help you go from there.
Old Mar 6, 2006 | 12:17 AM
Racerguy's Avatar
Racerguy
Hi Richard and welcome
Like Alfred said you'll need to get it scanned and see what trouble code turned the check engine light on. Most likely you just have a bad spark plug or COP (Coil On Plug).
Some parts stores such as Autozone will scan it for you for free. Just don't let them talk you into buying a bunch of parts without some more diagnosis though. If you post the trouble code here, not just the description of it, we should be able to help you with it.
Old Mar 6, 2006 | 01:02 PM
mdjohnson's Avatar
mdjohnson
Usually if the CE light is flashing the engine is missing if it stays on you have a problem.
Old Mar 7, 2006 | 03:36 PM
richard stone
problem solved
Just got the problem fixed, it was the COP's, THREE OF THEM!! #3 was shot and 5 & 7 were also misfiring, had to replace all three.
Old Mar 7, 2006 | 09:09 PM
Racerguy's Avatar
Racerguy
Good to hear that you got it cured
tbone6675
15
Sep 27, 2016 08:34 AM
Jnas860
Oct 28, 2011 08:36 PM
buba 11
Jan 28, 2011 07:44 AM
nakoakai
Jul 23, 2010 10:37 PM
Pam's Red
1978 - 1996 Big Bronco
20
Aug 21, 2004 06:06 AM
