Offroad & 4x4
front end identification
Old Mar 5, 2006 | 01:18 PM
Ford_250's Avatar
Ford_250
I have a 1982 4X4 and am rebuilding the whole truck. how do i know what type of front end i have. I've never got into the interworkings of the drive system so i don't know what all the numbers mean. Pretty much i need Ford front and rear end for dummies book
Old Mar 5, 2006 | 01:44 PM
MBBFord's Avatar
MBBFord
I want to say it is a TTB D50.
There should also be a little metal tag on the diff cover with all kinds of info on it.
Old Mar 5, 2006 | 10:04 PM
fishmanndotcom's Avatar
fishmanndotcom
if you have dual piston brake calipers you have a D50, if ytou have single piston calipers your front is a D44.
if your rear axle has a oil plug in the rear differential cover its a D60... if it does not and the fill plug is on the side on the forward section of the rear diff its a Sterling 10.25. if it has protruding hubs it is a full float, if not its a semi float.
whats your GVWR? if its over 8600 it'll have D50 front/D60 or 70 rear. if it is under it'll be D44 front/D60 rear
-cutts-
Old Mar 6, 2006 | 12:36 AM
mustange70's Avatar
mustange70
Cutts, the dual pistons brakes were avaible on the 44 to, as my 80 had the dual pistons calipers when it still had the dana 44 ttb. Easiest way to tell what you got is look at the hubs, if the hubs fill out the entire open wheel center then its a 50, if the hub tapers down and doesn't fill out the wheel centre then its a 44, odds are unless you got a 350 4wd (of which i've oonly ever seen one of those years with a ttb) you most likely have a 44ttb.
second 10.25 weren't avaible till about 85, in 82 it was either the dana 60/70 in the 250's and heavier, then the 1/2 tons either had the 8.8 or the 9".
Old Mar 9, 2006 | 09:09 PM
Ford_250's Avatar
Ford_250
i have the semi float i know that much. ill have to check the other things. im working on tearing the engine down right now so everything else got put on the back burner
Old Mar 9, 2006 | 09:39 PM
bremen242's Avatar
bremen242
8600 is Dana 44HD. 8800 is Dana 50.
Semi-float = Dana 44HD, Dana 60 SF rear.
My '85 has dual piston calipers on a Dana 44HD. 8600 GVWR
most stuff '86 and older is Dana 44HD.
Old Mar 9, 2006 | 10:12 PM
fishmanndotcom
well my 85 was 8600GVW and it had a D50... so i dunno
-cutts-
Old Mar 10, 2006 | 12:23 PM
mustange70's Avatar
mustange70
I wonder what the last year of the 60sf 35spline was, as thats what the rear axle i pulled out of 80 when i swapped my rear axle.
Old Mar 10, 2006 | 12:38 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
they still put them in vans dont they???? i think they have discs now though
Old Mar 10, 2006 | 02:33 PM
bremen242's Avatar
bremen242
-cutts-
really? the last x-cab F250 i saw was 8800, but it was a diesel.. It seems x-cabs got them as standard equip, maybe..
Old Mar 10, 2006 | 05:13 PM
mustange70's Avatar
mustange70
Last i checked the vans are using the sterling axle, but they used the dana's a for a while after they switched to the sterling's.
Old Mar 10, 2006 | 05:27 PM
82F100SWB's Avatar
82F100SWB
85+ F250 ex cab long beds are all HD's, 8800 GVWR, D50 front, 10.25 FF rear.
Reg cabs were standard with the 44HD, no matter what GVWR(8600 is max for a reg. cab) or engine. The 50 was avalable in a reg cab with the heavy GAWR packages(snowplow, camper, max front GAWR etc.)
I've never seen a F250 with single piston calipers, but, I haven't been around any LD's older than 87 or so though.
Old Mar 11, 2006 | 08:54 AM
bremen242's Avatar
bremen242
I've seen a couple '86 and older semifloat F250s (LD I would think), have thought to look at the calipers...
However, I could swear I saw an F250LD 87-91 with an 8 lug 8.8. it drove away before I could really look.
milrite007
Aug 15, 2016 09:44 PM
Lacadie17
1947 and Older Ford Trucks
May 1, 2016 07:30 AM
xtal_01
Nov 27, 2015 08:37 PM
octaneforce
Apr 17, 2013 04:16 PM
GAFordFan
Mar 22, 2003 10:05 PM
