360 to 460
Old Mar 1, 2001 | 06:55 PM
fozzy's Avatar
fozzy
360 to 460
Old Mar 2, 2001 | 10:57 PM
hillbillyk's Avatar
hillbillyk
360 to 460
I am putting a 460 into a 74 f-100 supercab, it has a 360 now, what all is needed to mount it, I have a big block c6 tranney now, which motor mount towers should I use, I have the fe towers, 351m/400 towers, and smallblock towers, also, what motor mounts should I use. What is the best way to hook up the electronic ignition that the motor has now, when the truck has points. Thanks
Old Mar 3, 2001 | 12:55 AM
daac's Avatar
daac
360 to 460
check with advance adapters. i can't find their adress right now, but i know you can find it in most any 4 wheel drive mag.
Old Mar 3, 2001 | 07:37 AM
Ford79's Avatar
Ford79
360 to 460
Go with the 351m/400 frame towers, L&L motor mounts , rear sump oil pan and truck manifolds. As far as the ignition goes, install an MSD ignition. All it needs to work with the current distributor is the MSD cable adapter to plug the MSD ignition into the Duraspark plug on the distributor. The instructions MSD supplies with their ignitions are easy to follow. Hope this helps.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
