axle/spring swap?
Old Feb 13, 2001 | 04:41 AM
jowilker's Avatar
jowilker
axle/spring swap?
Old Feb 25, 2001 | 07:04 PM
brychar's Avatar
brychar
axle/spring swap?
thinking of swapping a dana 60 rear and 3/4 ton rear springs onto my 1979 f-150 4x4. my current 9 inch is starting to hate life. i have an extra ford dana 60 with 4.10 gears. I would want to swith the 60 to 3.50 to match my current f-150 front (and for better gas mileage). Where is the best place to buy gears for this swap? Will the dana 60 carrier with the 4.10 gears accomodate the 3.50s?
also saw some 2700 lb rated rear springs in jc whitney that fit 79 f-150s. has anyone used these or would they recommend these springs as an upgrade? if not, what is a good way to upgrade?
thanks for the help.
bryan
Old Feb 26, 2001 | 12:01 AM
BigBrownTruck's Avatar
BigBrownTruck
axle/spring swap?
Are you going to carry two spare tires, w/ different rims, since their are more lugs on the Dana 60?
BBT
Old Mar 3, 2001 | 07:54 PM
Trail_Rider's Avatar
Trail_Rider
axle/spring swap?
I would think that the rears you are looking for would be readily available. One other thing you may want to keep in mind after you get the gearing straightened out is you'll want to run the same diameter tires front and rear.
Trail Rider
