Ignition problem
Old Mar 4, 2006 | 06:59 PM
happleberry's Avatar
happleberry
Question Ignition problem
I have a 76 f-150 and it ha trouble starting. Turn the key and it will just turn the engine over, if you rock the key back towards the off position and most of the way back again it will start. (sometimes) Any suggestions?
Old Mar 4, 2006 | 07:09 PM
Mil1ion's Avatar
Mil1ion
Mechanical Positional problem !
I think it's the Ignition switch
Old Mar 4, 2006 | 07:15 PM
happleberry
I replaced that today infact and still same thing
Old Mar 4, 2006 | 07:17 PM
Mil1ion's Avatar
Mil1ion
You replaced the whole switch (for the 1976 Year) or the tumbler ?
Old Mar 5, 2006 | 05:34 PM
happleberry
Yeah, the key, the switch and I replaced the brain box and the coil. Could it br the coil pick up ?
Old Mar 5, 2006 | 06:18 PM
Mil1ion's Avatar
Mil1ion
Does this happen Every Time you try to start it or intermittently ?
Old Mar 6, 2006 | 11:32 AM
73Custom's Avatar
73Custom
Just want to clear up one thing... are you aware that there are 2 parts to the in-dash ignition switch? The mechanical key and tumbler and the electrical switch that it moves... You need to replace the electrical part. Also inspect the wiring harness to the ignition, sometimes they melt and cause connection problems.
Marty
Old Mar 16, 2006 | 07:41 PM
happleberry
Found it
I am aware that the key switch is two pieces, I replaced them both because I couldn't get the tumbler out. It was actually the wireing to the brain bow that was fried. Thanks for the help
Old Mar 16, 2006 | 10:25 PM
77460f150's Avatar
77460f150
If this problem comes back check the mag pick up in the dist. I've seen a couple of these be intermittently bad. -Ed
Old Mar 17, 2006 | 11:40 AM
happleberry
Still not right
I am going to try the coil pick up, cause it isnt working right. Any suggestions on the removale of this part?
Old Mar 17, 2006 | 08:41 PM
77460f150's Avatar
77460f150
It's actually the magnetic pick up inside of the distributor, if you post a thread in the corresponding "engine forums" or do a search I'm sure you would find some helpful advice. When I had this trouble, I replaced the complete distributor assembly. At Auto Zone cost was $45.00 for complete dist (or $23.00 for just the magnetic pick up), for that I was able to get a new magnetic pick up, new bearings, true (straight) shaft, new gear and roll pin and vac. advance.I did not have to disasemble / reassemble the old dist. either, just remove and replace (15-20 min. compared to an hour or more). Once I had the new one and original one side by side I noticed that the original one was much more difficult to spin by hand. After replacing it I have had no further trouble. -Ed
Old Mar 18, 2006 | 02:40 PM
happleberry
Thanks
You have been very helpfull. Thank you very much.
I do need to re-time the engine after swaping out distributors, right?
Old Mar 18, 2006 | 03:01 PM
53fatfndr's Avatar
53fatfndr
Yes, if you change the distributor you will need to reset the timing.
