I have a fresh rebuilt 400 , and it gets very hot at idle, my old 400 did the same thing, I checked the idle mixture over and over, timing set around 17 degrees , and the radiator is a heavy duty modine about 2-3 years old, I have one of those fly-swatter fans, could that be the cause??? give me some inexpensive tips to try first before suggesting a rebuild, and or plasti-gauge job
Sean, There is a thread about a mile long in the archives, from the guy that had a service truck that boiled on him when idling at stops. I really don't remember if there was a solution or not. We kicked around electric fans (blowing in & out) different thermostats, fan shrouds, you name it.
If you don't have one, try a fan shroud and an electric (large) fan. :-)
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01]
[FONT COLOR="#0000ff" SIZE="3" FACE="Veranda"]
Why would someone suggest a rebuild on a fresh rebuilt motor? How fresh is the rebuild? Also, new rings generate more heat until break-in. That phenomena might be at work. Make sure you have a thermostat in the engine, running 50-50 mix of quality coolant, not just water and make sure you have a shroud on the radiator and a good fan. Not all fans are created equal as you already suspect.
[/FONT]
you mentioned the timing is set at 17 isnt that a bit much? especially if the motor is stock. on my 352 wich is more than slightly built i only run my timing at 13-14btdc. it is possible it has too much timing.
You didn't say what that 400 was bored to. These 400's were
thin walled and ran hot after boreing. You may consider another
type of fan but it may be useless. Start thinking 460.
That initial timing is too much. Also, the rebuilder could have installed the head gaskets on the wrong sides. They bolt on, but will block coolant passages if swapped.
I agree that 17 degrees BTDC at idle is excessive timing. Normal timing for the 400 is about 8-12 degrees BTDC. If the engine has a 351M damper instead of the 400 damper, the timing marks may be incorrect. I'd try to back the timing down to 10 degrees BTDC or so, and see if you can get a smooth idle with that timing.
Even though the radiator is only 2-3 years old, it could still be plugged. You should check that, maybe try flushing it. Fan shroud is also a good suggestion. I doubt an electric fan would improve things over what you've got.
Even though a new engine generates a little more heat than an engine that's already broken in, it shouldn't be significant if your cooling system is working properly.
As for overbore, that's a possible problem, but unlikely if it's not more than 0.030".
The main reason it is overheating at idle is because it isnt getting any air pushed to the engine versus when its moving it gets air pushed to it. Id try a different thermostate that opens up earliyer or a less pound cap. Good Luck!
Anthony DiPietro
79 F150 Ranger
How big of a problem is this? Does it only happen on hot days when it idles for a long time or is it getting hot sitting at stop light. We have 2 grain trucks at home with a 332 FE block and another off brand grain truck that i won't mention the name of with a 235 I6 and they will over heat if left idling for a real long time. I don't want to say that it is normal for extended idling to cause overheats but it does happen quite a bit with older trucks with older cooling systems.
Did you change the water pump and the thermostat? When I did my 400 rebuild the first therm. I put in didn't work. Had to go to a 180 degree therm. and then everything worked fine.
Also, my timing runs high too, 15 deg BTDC. If it's not pinging it shouldn't present any problems. However, you do want to check for correct installation of the distributor.
I don't think you should worry about the timeing being to high. I looked on the valve cover on my 1978 400m and it said it should be a 18 degrees btdc.
I knew a guy who had the same symptoms with his rebuild. Replaced everything trying to figure out why it kept overheating. then he realized he had the hoses to the waterpump backwards. Maybe?
well, It was a short block kit(now with 4.5k), so yes I put the head gaskets on correctly, the water pump is an old stock replacement with about 40k on it, I used a NEW 180 thermostat and a new 13lb. cap, I have the large 4 row radiator(2 years old)and I back flushed it with a water hose.
the cylinder walls were bored .040" over with silv-o-lite pistons, new rings, the works. I bought it from a reputable engine builder who has been established here for over 18 years.
I checked the distributor, I think the timing would have shown if it were a tooth off.
the fan shroud is in A++ shape, although I still have the OE fly-swatter fan.
UGHHH!!! summer is quickly on its way here in south TX!!!!
