1978 - 1996 Big Bronco
Tranny Swap
Old Mar 4, 2006 | 01:31 PM
busyboy31ca's Avatar
busyboy31ca
Tranny Swap
Just a question for you, I have a 1980 fullsize W/ 351m- c6 tranny, Is there an OD tranny that will fit the 351m bell housing bolt pattern, I need the extra gear for the highway, right now im running 4.10 in the diffs
Old Mar 4, 2006 | 01:47 PM
Kemicalburns's Avatar
Kemicalburns
the easiest would be to find a manual 5speed that bolted to a 460. the only auto would be the e4od and might be to much trouble because its electronic controlled
Old Mar 6, 2006 | 08:19 AM
mattri's Avatar
mattri
The ZF 5spd should fit. The 351m's had the bigger bell housing bolt patterns, you'd need to swap over the slave and linkage etc.
