P/S Pump mount
Old Mar 4, 2006 | 09:43 AM
Burt280's Avatar
Burt280
P/S Pump mount
Any body got a picture of the Power steering pump mounted on a Y-Block with the fan mounted above the water pump. Looks like I will have to change to the later model water pump and fan setup in able to get clearance for a belt and pulley to drive the power steering pump with my set up. Here is a picture of my 55 292 as it is now configured. Any suggestions for mounting the pump. BTW this engine already has the bracket installed for the AC pump that will mount low on the passenger side.
[IMG]https://www.ford-trucks.com/user_gal.../99966.520.390[/IMG]
Old Mar 4, 2006 | 02:08 PM
Walston's Avatar
Walston
Check out my gallery, several pictures. I think you will need to include the PS pump with the upper fan.
Old Mar 4, 2006 | 06:56 PM
e william's Avatar
e william
It depends on what pump...I'm using a toyota pump still in the frame cradel, put a dual pulley on the generator and mounted the pump cradle to the generator brackets. he toy. pump cradel also included the tensioner pulley and adjuster, so I just put a short belt over the pump, adjuster and the dual generator pulley. the belts run over the timing cover and over to the driver inner fender, then to the toyota steering unit.
In this pic you can see the pump cradel painted black
Old Mar 5, 2006 | 06:37 AM
Walston's Avatar
Walston
Nice looking Y-block! Good luck on your belt set up, I am sure someone can help with the right picture.
Old Mar 5, 2006 | 08:16 PM
Burt280's Avatar
Burt280
Great picts
Thanks for the pictures. They help a lot. Good looking engine e_william. Do you think you will ever add A/C to your truck.
Old Mar 5, 2006 | 09:39 PM
Walston's Avatar
Walston
We have talked about AC but not serious enough to do much research. I know there are a couple companies that make units for 57-60 and they claim they have set ups for Y-blocks, but I have checked them out in detail.
powerstroke72
2010 - 2014 Ford SVT F150 Raptor
39
Dec 11, 2009 01:54 PM
fxstbchopper
Dec 6, 2008 08:24 PM
fxstbchopper
35
Dec 1, 2008 10:23 AM
PinkStroker
91
Nov 13, 2008 10:51 AM
dwschmidt
Jun 16, 2008 07:20 PM
