1 ton rear end
Old Mar 6, 2001 | 11:56 AM
jford99's Avatar
jford99
1 ton rear end
Does anyone know how to tell the difference between a 3/4 ton and a 1 ton rear end. It has no tags that I can see.
Old Mar 6, 2001 | 02:13 PM
Chuck P.'s Avatar
Chuck P.
1 ton rear end
The 3/4 should be a Dana 60, the 1 ton would be a Dana 70, at least thru early to mid 80's. This is cast into the webbing around the cover or pinion usually (not always though), just "60" or "70".
Old Mar 6, 2001 | 06:32 PM
fatforty's Avatar
fatforty
1 ton rear end
Hi, you can also look for extra long axle studs and if it had dual wheels it should have line up pins installed in the axle.
John
Old Mar 6, 2001 | 06:34 PM
melovefords's Avatar
melovefords
1 ton rear end
zach5187
Sep 3, 2022 08:06 AM
Biff61
1947 and Older Ford Trucks
Aug 25, 2015 07:44 PM
jon on the mon
Sep 23, 2014 01:54 AM
86dieselnut
Jun 15, 2014 11:48 AM
PAwhiteboy
13
Mar 27, 2013 01:25 PM
