When ever I use my keyless entry to unlock my truck, i get in and start it up, the truck automatically locks itself. When after driving, when I shut the truck off, it unlocks itself. Theres been many of times where I almost locked my self out of the truck since I would start it up in themorning and let it warm up...If i closed the door, i wouldve been screwed.
(yes i have a backup key, but sometimes i warm up the truck at work or leaving other places)
on my 2005 screw, you can not lock your keys in the truck because if the key is in the ignition and you hit the door locks they just unlock automatically.
the only way is to use the key fob from outside the truck with the doors closed.
is this not the same on yours?
If you have a key pad like my Lariat, the way to beat this is to manually press down the door lock before you exit the truck if you want to let the truck warm up and still have it locked.
Take a look at your documentation or install schematic from your reciever unit. There should be something in there or a wiring diagram that will show you how to deactivate this feature. I mean if it locks and unlocks automatically...it has to be recieveing the signal from somewhere to do so.
