Wait to start indicator
Old Mar 2, 2006 | 10:23 PM
1stpwstk's Avatar
1stpwstk
....can someone please tell me why, between starts y'day, the "wait to start" indicator quit coming on? ....and hasn't come on today, dispite the fact it "turns over and starts" great? TIA
Old Mar 2, 2006 | 10:37 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old Mar 3, 2006 | 01:15 AM
GarryR's Avatar
GarryR
The wait to start light is on a different circuit than the glow plugs so even though the wts light is not lit the glow plugs may still be operating. Have you checked the fuses/
Old Mar 3, 2006 | 07:14 AM
walt1968's Avatar
walt1968
Maybe it has a glow plug saver installed? Just what I'm trying to do this weekend if I could get some info.
Old Mar 3, 2006 | 08:08 AM
DaBigTow's Avatar
DaBigTow
Watch the voltmeter when you turn on the ignition. It should jump to near mid-scale, then drop back to 1/4-scale. At 1/4-scale, it's lighting up the glowplugs. Wait a few seconds, then whack the starter; should light right off. Glowplugs will be off when the gauge returns to mid-scale or above.
On edit... the fuse for the lamp is #17 on a truck, #18 on E-series.
Old Mar 3, 2006 | 09:52 AM
1stpwstk's Avatar
1stpwstk
....thx again for your replies....
Old Mar 3, 2006 | 09:56 AM
MikeFromShiloh's Avatar
MikeFromShiloh
maybe the "wait to start" light bulb is shot
Old Mar 3, 2006 | 11:00 PM
GarryR's Avatar
GarryR
I installed a glow plug saver and it works great. I used a thermostat from a hot water heater and it sits atop my HPOP. Wired it in the line that the PCM uses to ground the GPR to make it operate.
Old Mar 4, 2006 | 10:20 PM
1stpwstk's Avatar
1stpwstk
....sorry fellas, I've been wrapped up in my biz, regardless, I'll let you know the outcome soon...(it does not have a glow plug saver)
Old Mar 5, 2006 | 06:16 PM
1stpwstk's Avatar
1stpwstk
......Okay, Okay....I got egg all over my face guys..."Push the clutch all the way to the floor, then turn the key to On".....BINGO!! ....we got lites Houston!....
(I'm goin' back to readn' for awhile)
