Computer Chips & Tuners
Tuner for S/C
Old Mar 2, 2006 | 08:26 PM
roush06f150's Avatar
roush06f150
Tuner for S/C
Does anyone know of a tuner I could use for a 2006 Roush S/C F150 FX4.I dont need a dash mounted unit,Im just looking to eliminate the speed limiter and rev limiter.My PCM was already reflashed by roush,but they will not deviate from the factory set speed and rev limiters because of warranty issues.The S/C runs full at 6 pounds of boost with a K@N air intake.
Old Mar 3, 2006 | 08:00 AM
MotorHaven Guy's Avatar
MotorHaven Guy
What's the PCM code they flashed it to? Likely, their code can't be modified (one of their engineers told me last week that they use a memory location in the PCM that the aftermarket tuning software can't touch yet). Let me know the code and I'll verify one way or another. Also, I don't believe they remove the rev limit, but will remove the speed limiter on request.
Old Mar 3, 2006 | 12:46 PM
pronstar's Avatar
pronstar
Where is your truck shifting at now?
The 5.4s don't really rev too high, with factory internals 5200 rpm or so (perhaps a bit higher, but not too much more for your 3-valve) would be about as high as you'd want to go...and a roots blower is more efficient at lower RPM.
Perhaps your rev limit is OK but your shift points are too low?
I run to 5200rpm on my centrifugal blower, but I've got crappy no-flow non-PI heads...so it's not a great comparison. But the rev limits for any 5.4 aren't sky-high on stock internals, as the piston stroke is long.
Just curious...
Old Mar 3, 2006 | 04:15 PM
roush06f150
tuner
My PCM code is 6L3A-12A650-CJB 3.55 gears and 675 rev. any info you can come up with will be greatly appreciated.My truck shifts right now out of 1st gear at 3500 rpm,the shifter is in drive with the od off.This seems low to me,does anyone find this average.
Old Mar 3, 2006 | 07:24 PM
pronstar's Avatar
pronstar
Yikes, that is very low. I bet it's your shift points and not your rev limit, especially if you can get more revs in other gears.
If you shift into first, and are able to get the revs up higher than 3500, then it is definitely your shift points.
Did they input the correct rear-end ratio for your truck? Do you have non-factory wheels?
After my dyno tunes, my shift points are always too low, we have to make adjustments afterward.
But something is definitely not right with your setup if you are shifting at such a low RPM.
Old Mar 3, 2006 | 09:36 PM
roush06f150
shift points
Now that you mention it my rear axle is 3.73 It seems that the PCM is calibrated to 3.55 I am also running on 20 inch wheels.I will definitely investigate further,thanks for the info.
Old Mar 7, 2006 | 08:20 AM
MotorHaven Guy
There should be a 4 digit code on the PCM. 3 letters followed by 1 number. The number you gave is the calibration id, and its not pulling up in the SCT software.
Old Mar 7, 2006 | 07:36 PM
roush06f150
Roush S/C
Unfortunately these are the only numbers I see on the pcm.Thanks for your time,energy and effort.I spoke to the people at Roush and they said my dealer should be able to reflash the pcm,I will hope to see them tomorrow.
f150_Roush_St3
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jan 18, 2007 01:05 PM
StarJack
2004 - 2008 F150
24
Jan 11, 2007 09:45 AM
ROUSH_STAGE3150
Jan 4, 2007 10:38 AM
redelsinore
Jul 14, 2006 01:37 PM
73mach1
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Jul 13, 2005 02:17 PM
