gear ratio question?
Old Mar 2, 2006 | 06:52 PM
Modified's Avatar
Modified
I have a 78 f250 sc with 4.11 axels. I plan on going to 38.5" tires which will put my new ratio to around 3.08. Do you all feel that is a deep enough gear for a 4x4 and for towing. I plan on rebuilding the engine with a butt load of torque but I have some concerns. What do you all think?
Old Mar 2, 2006 | 07:57 PM
73-79owner's Avatar
73-79owner
There is a formula that you can use to find out what gear you need to get your truck back to it stock power. You take the size you want to go to and divide it by the old tire size. The you multiply that number by the gear you have now. The number is what gear you need to have your truck run the same.
Ex. (35inch/29inch)=1.206*3.73=4.50 gear or a 4.56
Old Mar 2, 2006 | 08:03 PM
Modified's Avatar
Modified
Yeah I know of the Calculation. I am more curious as to what people feel about a 3.08 final gear ratio. Should help the mpg but I'm not sure how it will do towing.
Thanks for the help.
Old Mar 2, 2006 | 08:04 PM
73FOMO's Avatar
73FOMO
Didn't he say he had a 4.11? Not a 3.73? Will this formula work when going the opposite way?
Old Mar 2, 2006 | 08:06 PM
73-79owner's Avatar
73-79owner
The example I posted was just that ans example you can plug your own number into it.
73FOMO's Avatar
73FOMO
Personally, I would probably go with a 3.50 ratio if you are going to pull much, or be off road much. I know my 98 and 2000 f150 4x4's came with 3.55's I think. It had the towing package.
Old Mar 2, 2006 | 08:07 PM
73FOMO's Avatar
73FOMO
understand, it will work either way though?
Old Mar 2, 2006 | 08:10 PM
73FOMO's Avatar
73FOMO
When I said I would personally go with the 3.50, I was referring to final ratio taking into tire size.
Old Mar 2, 2006 | 09:54 PM
MBBFord's Avatar
MBBFord
Actually a 3.08 gear ratio won't give you better gas mileage, b/c your engine will have to strain more to get into it's power band, and by the time you get up to speed you wasted alot of gas, but your RPMs will be lower at highway speeds, but this truck will be for 4 wheeling and towing, so good RPMs isn't what your looking for.
If you had the money, regear to about 4.88 or just put that money into the engine, and give it plenty of power in all parts of the power band, helping gas consumtion on acceleration w/ the 4.11s.
Old Mar 2, 2006 | 09:58 PM
MBBFord's Avatar
MBBFord
That's right, I wouldn't want any less than 3.50 final gear ratio, if not 3.73, and depending on how much road and speed it sees, possibally even a 4.10 final gear ratio.
Old Mar 2, 2006 | 10:13 PM
Mil1ion's Avatar
Mil1ion
WEird,
Not one person asked what Engine & Transmission he has
I think that it will make a difference if he has a 302 or 460 or something in between.
Old Mar 3, 2006 | 12:39 AM
magicity's Avatar
magicity
what engine/trans?
depends on the engine trans combo. I run 4.10 gears in a 78 f-150, with 38.5 boggers, BUILT c-6, 514 ci engine. With this I pull as good as any diesel,(except mileage-ugh 6-ish). But with a mild 460 or 400m, Gear it to a 4.56 or 4.88.
Old Mar 3, 2006 | 03:35 AM
Modified's Avatar
Modified
Sorry Folks... I have a 400 that when rebuilt will be a 434 stroker and a C6 tranny through NP 205 to Dana 60 axels
Old Mar 3, 2006 | 11:31 AM
73FOMO's Avatar
73FOMO
I think you would be fine with a 3.50 FINAL ratio.
OldWoodsDiesel
19
Nov 14, 2012 09:10 AM
drivembig
Mar 10, 2010 07:34 AM
BrentNewland
Jul 18, 2008 10:57 AM
James Hewett
Jul 23, 2003 12:49 AM
6772crewcabs
Feb 5, 2002 02:53 PM
