power steering radiator??
Old Mar 14, 2001 | 08:16 PM
tbejr's Avatar
tbejr
Hi. I have two questions. I have a 70 f100 360. Number one is what is that little finned looking thing that goes to my power steering pump that looks like a little radiator?
#2 I have Air conditioning( I think). I dont have an air pump just a console underneath the dash. And on the front side of
the radiator is what looks like a tranny cooler, but it has a hose going to the heater core. I want to mount a tranny cooler. So is this part of the air con unit? do I have to disconnect it to run a tranny cooler? thanks for the help.
Thomas Endicott
Old Mar 14, 2001 | 08:26 PM
jeff70's Avatar
jeff70
That little thing on you power steering is a fluid cooler, also i would guess that that thing in front of your radiator is a condenser for the AC. One way to tell is follow the hoses, if it goes back to the tranny its a tranny cooler.
Old Mar 15, 2001 | 02:48 PM
dre's Avatar
dre
No,
Do not disconnect it if it runs back to the heater core opening on the firewall. That's the A/C condenser.
At the bottom of your radiator you should see two small steel lines screwed into it. these lines run back to your trans.(auto).
The bottom of the radiator has a built in cooler tank for the transmission.
If you desire extra cooling of the Trans. you can run a external cooler off of one of those lines.
If room permits, mount the cooler in front of the condenser.
All Auto Parts Stores sell universal coolers from about $20.00 and up.
Dre'
1978 F-150, 460ci(750cfm,Edelbrock Performer,Dynomax Ceramic Coated headers,etc.)Auto-C6,3:70.1 - 9" Posi.
Old Mar 15, 2001 | 03:39 PM
buzzard's Avatar
buzzard
If you don't plan on renovating the A/C system, get rid of the condensor. All it's doing is blocking air flow from your radiator.
Old Mar 15, 2001 | 04:27 PM
tbejr's Avatar
tbejr
Thanx for the help guys.
Old Mar 16, 2001 | 08:32 AM
fozzy's Avatar
fozzy
I agreee with buzzard, gut the old ac out unless you can afford to keep it in shape ...you will lose about 100lbs front end weight
https://www.ford-trucks.com/dcforum/User_files/3a9df0394b631ce6.gif
77'FORD F150 XLT 400
Old Mar 16, 2001 | 12:50 PM
BB's Avatar
BB
