limited slip clutch
the cluth should only chatter when turning and it is slipping. going straight it does notohing and should not chatter. if it chatters when turning, you need to remove the axle cover, clean out the old lube, install new synthetic gear lube and put the 7 ounces of limitied slip addative in the oil. if you dont put the addative inside, the cluthc will chatter when turning.
