98 explorer eddie bauer heating problem
Old Mar 1, 2006 | 02:38 PM
sdswan's Avatar
sdswan
I have an Eddie Bauer with automatic temp control. It only blows full hot if the display is set above 65 degrees, if it is set on 60 degrees it will blow cool, not cold. No in between. Is it simply the $600 dollar dash control unit that is bad or is there a less expensive fix?
Old Mar 1, 2006 | 03:47 PM
hank_48's Avatar
hank_48
You may have the dreaded "Blend Door Problem". Check the very 1st post on the forum (Free Blend Door Fix) to see if you got bitten.
Old Mar 1, 2006 | 04:56 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome sdswan to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
