installing aussie locker this weekend - Any tips/tricks/stuff i should replace
I bought an aussie lunch box locker and im installing it into my 8.8 rear end this weekend. Any tips/tricks/ stuff i should/can replace while im in there? Im told its supposed to be pretty easy to replace but id like to at least have some ideas on what i can do for preventative maintenance while i haev everything out.
Replace the outer axle seals, pinon seals, and gear oil. Check the u-joints and R&R those if necessary. There a search in the offroad or axle Forums.
Try the installation manual on http://www.powertrax.com/noslip.html , Aussie an Powertrax are very similar and the installation should be the same. Do your research will help the installation process.
