INTERVAL WIPERS PROBLEM
Old Mar 19, 2001 | 07:02 AM
4byford's Avatar
4byford
My 79 Bronco with the optional interval wipers has a gremlin. Since electrical isn't my forte, I am wondering if anyone has seen this same problem and has a solution. My wipers will not shut off! Once turned on, they will stay on even if the switch is shut off. To turn off the wipers, the ignition has to be shut off at the EXACT moment the wipers are down (the park mode at the bottom of the windshield), if not, the wipers will stay running. The 2 speeds work correctly, but when the switch is rotated to counter clockwise to the interval mode, the wipers stay at low speed. I have replaced the switch, electronic wiper black box, and checked the ground, with no luck. The control box was hideously expensive, and I hope that isn't the problem- I may convert back to regular wipers if that is the case. Any help would be much appreciated!!!
Old Mar 19, 2001 | 09:43 AM
etobolski's Avatar
etobolski
It sounds to me like the black delay box has a short in it somewhere. Rather than buying a new one, go to the junkyard. The 80's trucks with delay wipers plug right in to your existing wires. The only change is that the new style switch doesn't have a separate hot wire coming into it for the w/s washer pump. These are easier to find, and cheaper. I got four of the switches and boxes for $15. Good luck.
Eric Tobolski
Old Mar 19, 2001 | 12:06 PM
weldman's Avatar
weldman
How do you hookup the washer system then??
I can't find the interval system new (like I've heard is possible), and haven't checked the 'yards yet. (I WANT INTERVAL WIPERS)
Eric, do you have any systems for a 78? (not the 80's style)
Thanks
1978 F250 Ranger 4x4 - 351M
hillbillyk's Avatar
hillbillyk
Mine did this once, I had to pull the motor and clean all the contacts in it, they had some corrosion, and the contact to "park" the wipers was not working correctly.
Old Mar 19, 2001 | 12:08 PM
weldman's Avatar
weldman
I know lmc has them (the switch anyway), but they are too damn expensive!($55US w/o the control box)
Matt
Old Mar 19, 2001 | 07:27 PM
classyfish's Avatar
classyfish
I have picked up quite a few (6) in the last year or two. That is excluding the 3 I allready put in my Ford trucks. The ones I have are from 1977, 1978, 1979's. I could part with 5 or 6 of them. send me a message.
Kevin, dowm to 5 foot drifts by my garage in IOWA
Old Mar 19, 2001 | 10:40 PM
classyfish's Avatar
classyfish
oh, by the way the 6 have the control thing and the black box. there complete operational units.
kevin
Old Mar 19, 2001 | 11:22 PM
weldman's Avatar
weldman
How much classyfish?
Do you have the actual switches too?
Matt
PS- already sent you a private message!
Old Mar 20, 2001 | 08:26 AM
classyfish's Avatar
classyfish
Sorry Matt,
I did not receive a pesonal message from you. I sent one back so hopefully you get it
Kevin
Old Mar 20, 2001 | 06:38 PM
fozzy's Avatar
fozzy
I had the same problem in my 77 f150, it was corroded connections/ground.switch is still fine
https://www.ford-trucks.com/dcforum/User_files/3a9df0394b631ce6.gif
77'FORD F150 XLT 400
Old Mar 20, 2001 | 07:45 PM
jford99's Avatar
jford99
