Sponsored by: Real Truck
2001 Ford F250 with Multiple Problems- Please HELP!!!
Old Feb 28, 2006 | 08:36 PM
artchic311's Avatar
artchic311
I have a 2001 Ford F250 with gas engine and automatic trans. Last night I drove 25 miles home (not towing anything) with no problem. The truck sat parked for about 4 hours, and then I drove through my field up a hill. I unloaded my dogbox and went to back up and the backup lights didn't work. Then I noticed the TCIL light that indicates the OD is off was flashing. that is the first time it has done that. I drove the truck back down the hill and parked it. I tried to re-start the truck and it does absolutely nothing when I turn the key. No sounds, no nothing. What is wrong??? Any help will be greatly appreciated!
Old Feb 28, 2006 | 08:44 PM
rwilimo's Avatar
rwilimo
I would check all harness connectors going to the transmission (some may be up in the engine compartment) If that's not it, check all the fuses.
Old Feb 28, 2006 | 08:50 PM
artchic311's Avatar
artchic311
Thanks!
Thanks for your reply. I'm afraid I know almost nothing about the inner workings of my truck. When I check the fuses, should I just be checking the ones in that are accessible from the cab of the truck or are there more? Thanks again for your help.
Old Mar 1, 2006 | 06:43 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome artchic311 to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Mar 1, 2006 | 12:08 PM
devildog_0431's Avatar
devildog_0431
Does your Truck have battery power at all ? If not...start w/ the battery. I know that the Transmission shift points are controlled by the battery, that's where I would start, hope it helps. Does your Starter Solenoid make a clunk sound when u go to start it ? try turning you igintion on if you have power, leave the key there....take a pair of jumper cables off your battery and ground the black on your starter, and put the positive on the power lead of your starter, then jump the igition lead to the power w/ a screwdriver. Hard to tell what's goin off if I'm not there w/ the problem so I'm just throwin ideas at ya, good luck.
Old Mar 1, 2006 | 12:25 PM
Casey's Avatar
Casey
Since the OD light was flashing, there's a code stored in the truck's computer. If you had that code it would help a lot. A Ford specific OBDII scan tool is needed to read the code.
All of the things you mention involve the Transmission Range Sensor (TRS.) It's mounted on the driver's side of the transmission, where the shifter cable attaches. It is the sensor that has a wiring harness plugged in. It controls the backup lights and also prevents the starter from operating unless the trans is in park or neutral. If it fails it will set a code that flashes the OD light, it can disable the backup lights, and it can keep the starter from operating. I think the TRS either died or is unplugged.
Old Mar 1, 2006 | 05:38 PM
devildog_0431
Interesting
Old Mar 1, 2006 | 05:49 PM
99f350sd's Avatar
99f350sd
Do the headlights work? Is the battery dead? Is your alt bad? Maybe
You said no lights or buzzers. chimes etc. Maybe your batt was going dead.
Dick
Old Mar 1, 2006 | 07:02 PM
FortyFords's Avatar
FortyFords
I would think you might have had something hit the the switch mounted on the transmission.Where the shifter connects there is a neutral /park safety sw it may have gotten hit buy a branch or rock going through the field or the wiring to it may have got caught on something.
Rich
Old Mar 2, 2006 | 09:54 AM
artchic311's Avatar
artchic311
Smile It is Fixed! Thanks!
Thank you to everybody for the great advice. It was the wiring to the safety switch mentioned by fortyfords. All I had to do was plug it back in and all is well. Thanks again to everyone for the help!!
Old Mar 2, 2006 | 10:27 AM
Big Orn's Avatar
Big Orn
Hey!!! FortyFords - you da man!
Old Mar 2, 2006 | 06:02 PM
devildog_0431
I love the word.....FIXED
Old Mar 2, 2006 | 06:16 PM
99f350sd's Avatar
99f350sd
Yah Forty you still got it...don't give up just yet..LOL good job!
Dick
Old Mar 2, 2006 | 06:26 PM
captchas's Avatar
captchas
Guest
don't we all. esp when it's a FREE FIX.
