Door Locks
Old Mar 20, 2001 | 04:54 PM
mrpelicanpants's Avatar
mrpelicanpants
Door Locks
Hey guys. New poster here, but I know you guys will have the answers.
I recently acquired a '69 F100 4x4 SWB that is great except for the door locks. The previous owner replaced the doors but neglected to retain the original door locks. This model year couldn't be locked from the outside without the key--if you push down the button and shut the door, it unlocks. My '79 F100 is handier in that you can just push the button, shut the door and it remains locked.
I have to replace the door locks anyway, so I have two questions:
1) Will later model door locks bolt in with no mods?
2) What model year did the door locks switch to the kind in my '79?
Thanks in advance for your help!
Old Mar 20, 2001 | 06:06 PM
mgessner's Avatar
mgessner
Door Locks
At the risk of overstating the obvious, what happens if you hold the handle when you close the door? My Dad's '69 Camaro will only stay locked if you hold the handle. (My Maxima, my 280Z, and my friend's '67 Cougar all do the same thing.) If this is the case, it is not the door lock, but the door opening mechanism that would have to be replaced. I'm not sure if those parts are interchangeable from 67-72 and 73-79.
Old Mar 20, 2001 | 07:28 PM
hotrodford_88's Avatar
hotrodford_88
Door Locks
I had a 66 mustang that would do the same thing. You couldn't lock the door and then close it, no matter what. It had new door locks, and latches along with handles. I believe that is the way it was designed. I even tried the obvious holding the button down on mine, and it wouldn't work.
The 65 F-100 I now have is the same way, if I lock the door bewfore closing it, you can't push in the button at all. And it does the same thing, lock it, close it and it unlocks.
I knoda like it that way, it keeps people from locking the keys in my truck!
1988 F-150, SWB, 5.0 EFI (formerly 4.9 EFI), M5OD 5 speed, 3.08 gears, Summit shorty truck headers, Custom built Flowmaster exhaust system. Force 4 LP6000 lightbar, Federal signal PA-300 100 watt siren, Icom IC-V100 50 watt mobile radio.
1965 F-100 (just purchased 1/18/01), SWB, 390, C-6 auto. Dual exhaust, Not much else to do to it.
Can see both below.
[link:www.geocities.com/hotrodford_88/|Hotrodford_88's Webpage]
Old Mar 20, 2001 | 07:32 PM
jowilker's Avatar
jowilker
Door Locks
You might just test try it and see what would happen. Try putting pieces of one door from the newer truck in the older truck. You should be able to test it and put it all back in an hour. :-)
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quite of night you can hear chevies rusting away.
Old Mar 20, 2001 | 10:30 PM
GWB's Avatar
GWB
Door Locks
Myself would take panel off and get number off of lock (passenger side) and locksmith will make a key or like I did remove locks and had them key to Ignition key so theres one key.That systems sure makes it hard to lock your keys in the truck.
GWB
Old Mar 20, 2001 | 10:37 PM
hotrodford_88
Door Locks
Actually to be perfectly honest, it should all be one key anyway. That's factory if I'm not mistaken?
Can see both below.
Old Mar 21, 2001 | 12:17 PM
mrpelicanpants
Door Locks
Thanks for all the help guys. I'm just going to take out the cylinders and have the local locksmith make a couple of keys (~$20). Doesn't solve the problem of only being able to lock from outside, but it'll keep me from locking my keys in it, and I shouldn't be in such a hurry that a little inconvenience would matter. After all, you don't buy a 30 year old truck for convenience. Thanks again.
Old Mar 21, 2001 | 12:20 PM
bigsixguy's Avatar
bigsixguy
Door Locks
