2001 Expedition 5.4L- Rough Acceleration
Old Feb 28, 2006 | 06:45 PM
jle70's Avatar
jle70
I recently bought this, it has 68,000 mi. It started running ruff, and Service Engine light came on. I took it to a Ford shop they diagnosed it as #2 bank O2 Sensor. I replaced it and it did help. But, it seems to still have a slight "Stutter" in acceleration. I am new to this motor, not to sure of it's general troubleshooting yet.
Old Feb 28, 2006 | 08:20 PM
coldairintake's Avatar
coldairintake
Could be any number of things. Wouldn't hurt to go ahead and replace the bank 1 sensor Bosch part 15716 at autozone ran me about $45.
Old Mar 1, 2006 | 03:58 AM
lynnr's Avatar
lynnr
Do you have the *actual* code? P0xxx?
Old Mar 2, 2006 | 02:07 AM
jle70's Avatar
jle70
No I don't, I didn't write it down. I just was told the O2 sensor bank #2 was bad. I just don't know what made it "bad".
Old Mar 2, 2006 | 08:54 AM
projectSHO89's Avatar
projectSHO89
O2 sensors seldom cause misfires...
Need actual codes... If the SES is on, there should be stored codes.
Steve
Old Mar 2, 2006 | 12:03 PM
jle70's Avatar
jle70
I am going to buy an Actron Scanner this weekend. I will try to get some live data.
Old Mar 2, 2006 | 12:25 PM
projectSHO89
Actron makes both code readers and scan tools. There is a significant difference in the device's capabilities between the two categories. See Actron's website for more details.
If you own or intend to own vehicles made in roughly '04 and later, be sure you get a CAN capable or upgradeable model.
Steve
Old Mar 2, 2006 | 12:40 PM
waboose's Avatar
waboose
First time givin info on here but sounds like u have a misfire somewhere, i'll bet its one of your coils you might want to check this out, i just went through this on my 1997 expedition, but the milage on my truck was 232,000 kilometers or about 143,000 miles.
Old Mar 2, 2006 | 12:41 PM
jle70's Avatar
jle70
I am looking at Actron OBD-2 Autoscanner Model CP9135.
Old Mar 2, 2006 | 12:46 PM
jle70's Avatar
jle70
That's what I thought, and told the Ford mechanic. He said that it was not a coil. The only thing he said was wrong was O2 Sensor.
Old Mar 3, 2006 | 11:59 AM
gibsonj's Avatar
gibsonj
I would not immediately blame the O2 sensor. Sometimes a vacuum leak can fake the computer into overcorrecting, causing a bank to lean out, which then causes the O2 sensor to sense out of range.
A common problem on 5.4L Tritons is a hole in the vacuum elbow connecting to the PCV valve. This elbow is not easy to see or get at, as it sits at the back of the engine under the intake. You pretty much have to feel for it. Anyway, the elbow deterioration is common failure, and will cause all sorts of symptoms, like rough idle, poor acceleration, and even an O2 lean condition.
Old Mar 3, 2006 | 04:59 PM
jle70's Avatar
jle70
I will check the pcv connection out. Thanks for all the input. Is there a better replacement that won't crack open or leak?
Old Mar 4, 2006 | 10:21 AM
coldairintake
You have to get the entire assembley from the dealer. It comes with new pcv valve, hose, elbow. It's possible that the pcv elbow is cracked at the intake.
But if it's not giving a misfire code, and reads o2 sensor, that could be it. PCV assembly runs about $35 at the dealer.
Old Mar 6, 2006 | 08:31 AM
gibsonj's Avatar
gibsonj
Not that I have heard about. The connector is elbow, and the heat back there deteriorates the rubber over time. Any rubber replacement will dry rot and eventually crack. You just have to be aware this is a common problem, and check it whenever you have acceleration stumbles or rough idle conditions. BTW, you have to feel for this connector---its impossible to see without a mirror. The hole usually occurs right in the bend of the elbow.
Old Mar 8, 2006 | 07:18 PM
jle70's Avatar
jle70
OK, I just checked the PVC hose and elbow. I also checked all Primary resistance on bank #2 coils, since that is the side that gave me a bad O2 Sensor. They all were fine. I guess I don't know what to do at this point. Wait until I get Scanner that will pick up live data?
