Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Removing rear quarter panel--tool?
Old Sep 28, 2002 | 03:08 AM
DailyDriver's Avatar
DailyDriver
Old Oct 1, 2002 | 03:14 PM
tombob's Avatar
tombob
Post Removing rear quarter panel--tool?
What would be the best way to cut off the rusted portions of the rear quarter panel on my old Bronco? I would then replace the quarter panel with an after market job. I am a long time woodworker who is making the transition to body/metal work.
So, can I make a decent cut with a metal cutting disk on my 4" angle grinder?
Or, should I use the metal blade on my reciprocating saw? I thought that might cut too deep, though.
Then I have read that the replacment panel can be attached using rivets or screws, which then would be ground down before using filler.
Any thoughts would be appreciated. Keep in mind this isn't a restoration job, since the Bronco is my faithful fishing/hunting truck. It just getting too full of holes for my taste. Runs great though.
Old Oct 1, 2002 | 08:38 PM
mtford1's Avatar
mtford1
I use Zip cuts on my angle grinder. They are 3/64ths of an inch thick and make a nice, fast cut.
Old Oct 2, 2002 | 12:26 AM
Torque1st's Avatar
Torque1st
Posting Legend
Remember to wear heavy gloves, safety glasses and a face shield. If those cutting disks get jammed and break they can fragment badly. Do not ever put your body parts in line with the rotating disk.
THINK SAFETY!
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
