Help with AOD problem
Old Feb 28, 2006 | 05:05 PM
silverselkie56's Avatar
silverselkie56
1986 Ford Econoline Van with AOD Tranny. When accelerating from 2nd to 3rd, it shuts down like I have let off on the accelerator until I let up on accelerator and step on it again and then will engage. It does not do this when the engine temp is cold. Any advice on this, am at a loss.
Old Mar 1, 2006 | 01:15 PM
l-m tech's Avatar
l-m tech
check for a weak fuel pump,or restricted filter.press. should be 32 psi min.also check the press. if possible while driving. this would be the first place i would start
