Supercharger help!
Old Feb 28, 2006 | 04:29 PM
f100/1982's Avatar
f100/1982
Supercharger help!
Does anybody know if Edelbrock makes a supercharger for a carbureted 302? If not...does anybody have any suggestions as to what company makes a good one to put on that 302? How much trouble would it be to supercharge the motor anyhow?
Old Feb 28, 2006 | 06:06 PM
1970Custom's Avatar
1970Custom
Edelbrock doesn't but if you can get ahold of a Summit mag there's a roots type blower in there, about 2,500.
Summit
Also BDS makes a r.t blower for the 302 as well
BDS
you can get a cetrifugal type but need the propper supplys to make it feed into the carb.
Old Mar 2, 2006 | 04:09 PM
f100/1982's Avatar
f100/1982
What is the difference between roots type and centrifugal? I've heard these terms before but don't know what they mean. All I know is that a Ford Lightning has a roots type.
Old Mar 2, 2006 | 05:08 PM
f460's Avatar
f460
Paxton showed off a new Novi 1000 for carburetor use. Should be able to check it out on their website. a ROOTS blower has 2 lobes that mesh and push the air into the engine and run at fairly low rpms around 10,000 -14,000. Centrifugal supercharges use a wheel, fairly small in diameter, with blades and run at very high rpms 40,000 and up. This requires a wheel (impeller) that is efficient at high "hang on" when the rpm's rise.
Old Mar 2, 2006 | 11:52 PM
1970Custom's Avatar
1970Custom
A centrifugal could be considered like a belt driven turbo so to speak.
Most truck guys like the roots for the pure fact they work down low.
