whats everybody using...
Old Feb 28, 2006 | 04:21 PM
Six Niner's Avatar
Six Niner
hey whats everybody using for intake gaskets? im prolly gonna have to reseal mine. joy.
Old Feb 28, 2006 | 04:28 PM
1975Ford's Avatar
1975Ford
Felpro Gaskets, with a good bead of RTV silicone on the sides where the cork gaskets joins up with the gaskets for the cylinders (heads).
_____
Buck "RS 9000 going up front and back of the 1976 F150, Smoothing out my ride"
1975 Ford F150 4x4, 4 spd, NP205, 390 cid
1976 Ford F150 4x4, 4 spd, NP 205, 360 cid
1975 Ford F250 4x4, 4 spd, NP 205, 400 cid, Hi boy
1978 Ford F150 4x2, 5 spd, 302 cid
Old Feb 28, 2006 | 06:49 PM
FEmtnmax's Avatar
FEmtnmax
I was going to try Mr. Gasket, as they have more squish to them than Felpro. Anyone use the MRG and had good or bad luck?
Old Feb 28, 2006 | 10:02 PM
gtex's Avatar
gtex
Victor NitroSeal from Napa. Plenty of black RTV in the where the heads/intrake/manifold meet and some around teh water ports. I also used the copper spray on gasket just to help on both sides of teh intake gasket.
Old Feb 28, 2006 | 11:25 PM
jj22ee's Avatar
jj22ee
i am getting ready to install my intake exactly where should I put RTV.
Old Mar 1, 2006 | 08:15 AM
1975Ford's Avatar
1975Ford
On the front and back corners of where the intake joins up with the engine block and cylinder head. Right where you see the head gaskets corners.
Old Mar 1, 2006 | 11:12 AM
bertha66's Avatar
bertha66
If you have the time, what I like to do is put down a bead of RTV on the ends where the cork gaskets are and use a spray sealer on the surface of the heads, then put the gaskets on and just sit the intake on the engine and let it sit a dry. Then pick the intake off and seal the tops on the gaskets and bolt the intake on. I do this so the cork stays in place and I get no oil leaks out of the ends.
Old Mar 1, 2006 | 01:20 PM
tastyklair's Avatar
tastyklair
Most here I believe throw away the end gaskets and just use a bead of silicone there. The ends tend to slide out easily otherwise. Try to make sure you seal everything well. Lots of posts on here about the intake sucking oil into the intake and burning it. Make sur your intake bolts are not bottoming out in the hole before they are up to torque if it's an aluminum manifold.
Old Mar 1, 2006 | 10:49 PM
zsir's Avatar
zsir
I didn't know Mr Gaskets were still available....I couldn't find any when I needed some ....
Old Mar 2, 2006 | 05:22 PM
Tyqmonn's Avatar
Tyqmonn
What I do with mine is take a center punch and make a line of punch marks across both ends of the block and both ends of the intake then I use a bead of Ultra Black RTV on both ends. The punch marks keep the RTV in place just in case it doesn't adhere all the way across. And yes I do clean the surfaces with solvent, but sometimes you can get a little oil from your fingers on the surface without realizing it.
Old Mar 3, 2006 | 07:38 AM
Six Niner's Avatar
Six Niner
looks like its this weekends project. ive got a diesel powered 35 ton crane coming over to lift the intake (just kidding). hopefully this time itll seal and not suck through the intake ports. thanks for the responses. ill prolly go with the victor nitroseals.
Old Mar 3, 2006 | 07:50 AM
GLR's Avatar
GLR
We used to do the center punch thing at the dealership, and it does work well. Some of the bigger trucks we had so much problems with, one of the guys would drill a few 1/16" holes in the block and insert 1/16" welding rod to keep the cork from sliding. We also made up a tool using an auto trans metal clutch disc with a bolt welded to it. This would screw into the carb where the air cleaner is bolted down. Insert pipe through the disc, two guys, one on each end of the pipe and another guiding the manifold in place. Another hint if you don't try to get the by-pass hose in at the same time as the manifold, is to cut a slight bevel on each end of the hose, this allows a little bend so it can slide in place. It's always fun...
Old Mar 3, 2006 | 11:06 AM
tonpartain's Avatar
tonpartain
Anyone have the part number for the Mr. Gasket intake gasket? I did a quick check of their web site and did not find anything.
Old Mar 3, 2006 | 11:35 AM
FalconStng's Avatar
FalconStng
I also have been unable to locate the Mr. Gasket intake gasket. I had several people recommend the Mr. Gasket intake gasket. I went to one of their local distributors and they said it was not available for the FE's.
Old Mar 3, 2006 | 12:37 PM
rusty70f100's Avatar
rusty70f100
Summit part number MRG-201G.
cps
Dec 7, 2012 04:21 PM
3golfjack
Jan 8, 2012 11:22 AM
nightrain04
New Member Introductions
Feb 2, 2008 11:31 AM
taisa899
Ontario Chapter
26
Mar 13, 2007 07:18 PM
03_PSD
Nov 17, 2006 02:31 PM
