Holley Carb Problem
Old Feb 28, 2006 | 01:49 PM
idealtrucks's Avatar
idealtrucks
Holley Carb Problem
I have an aftermarket Holley 650. I recently put a rebuild kit in it. It runs good, but it has a slow leak in it. After I cut it off and let it sit overnight or something like that, there is gas puddled up on the manifold. It appears to be leaking around the secondary throttle plate shaft. Has anyone else had this problem and how can I stop it?
Old Mar 2, 2006 | 02:37 AM
lee's Avatar
lee
Hi,
Ensure that the floats are set to the correct level.
Lee
Old Mar 2, 2006 | 10:12 AM
idealtrucks
I've got the floats adjusted pretty good I think. The front one I know is adjusted good, butt he back one is adjusted down about as low as it will go, but there is still gas that will run out of the hole on the side of the bowl when you take out the plug
Old Mar 2, 2006 | 09:19 PM
Ford_Six's Avatar
Ford_Six
There is probably something holding the needle open on the rear bowl.
Old Mar 2, 2006 | 09:34 PM
jade79's Avatar
jade79
When you say you see gas puddled up on the intake, I assume you mean the outside? I'd take it back off and make sure the rear float bowl gasket or fuel line isnt leaking and running down to where it looks like it's coming out of the throttle shaft. If it is coming out of the throttle shaft, I'd still suspect the float. I've seen brass ones develop pin holes and cause it to sink like a boat causinig it to keep the needle valve open. The foam ones can also absorb fuel and do the same.
Old Mar 4, 2006 | 05:19 PM
LxMan1's Avatar
LxMan1
Remove the needle and seat and look at the sealing point. It may have a small piece of debris in it. Blow it out good and it should be ok. Make sure the the outer o-ring fits snug when you reinstall the assembly in the carb.
Old Mar 5, 2006 | 12:49 PM
Bdox's Avatar
Bdox
One of the above suggestions should fix the problem. I have had a similar problem caused by gasoline percolating in the float bowl after shut-down with the engine hot. This was fixed by adding an isolator block under the carb so that it didn't absorb so much heat from the manifold.
Old Mar 6, 2006 | 02:32 PM
idealtrucks
Well thanks for the help here. I'll check to see if there is a hole in the float maybe. I removed the back needle valvle with the carb still on the car and used my mouth to blow in it, and it worked, but ill check again.
