2 choke cables?
Old Feb 28, 2006 | 11:30 AM
I6power's Avatar
I6power
2 choke cables?
back when i bought my truck, it had 2 choke cables that were hooked up and functioned normally. When i got it the motor had to be replaced. After that only 1 of the cables was hooked up. So where does the other one go? The one thats hooked up pulls the butterfly valve closed, so i dont know what the other one does, or where it goes.
Old Feb 28, 2006 | 07:29 PM
srercrcr's Avatar
srercrcr
Is the fast idle working OK?
If not, maybe somebody rigged it to a separate cable.
Old Feb 28, 2006 | 08:23 PM
Bdox's Avatar
Bdox
Shouldn't need two.
Maybe someone made a hillbilly cruise control(?)
Old Feb 28, 2006 | 08:43 PM
'70F100Owner's Avatar
'70F100Owner
When I got my truck out of the field that is what the choke was, a hillbilly cruise control/fast idle. They did theirs the correct way and had them separate
Old Feb 28, 2006 | 09:00 PM
I6power's Avatar
I6power
ahh you guys are good. needless to say the previous owner was a bit of a redneck and he did a few custom things to it
Old Feb 28, 2006 | 09:10 PM
jongeers's Avatar
jongeers
Back when my truck was made (and I don't know for how much longer) there was the standard choke cable and available as an option, a throttle cable a/k/a hillbilly cruise control. As the name implies, it connected to the carburetor the same place the gas pedal does. If you ever paced a piece of farm machinery through a field, you know why it was offered. If you haven't, think of hay/straw balers or combines that can empty themselves as they go along. The throttle control would also have been useful to anyone with something attached to the PTO output on the transfer case, at least on a truck like mine which has such.
Old Feb 28, 2006 | 09:15 PM
Bdox's Avatar
Bdox
Long ago it was a common item. Certain machinery obviously have a need for it but throttle cables on road vehicles were outlawed way back when.
Considering all the people that panic and step on the gas pedal instead of the brake, it's not hard to imagine why.
Old Feb 28, 2006 | 09:22 PM
jongeers's Avatar
jongeers
Bdox is right. Be glad you now know the origin and connection point of the 2nd cable, but don't hook it up.
1986F150six
23
Dec 22, 2012 09:31 PM
67FEranger
Dec 12, 2012 03:28 PM
rspreston63
Feb 23, 2010 04:11 PM
scottlane
Nov 28, 2005 11:15 AM
92Flare150
Feb 4, 2004 09:18 PM
