Bad Starting 95 PSD
Old Feb 28, 2006 | 11:10 AM
Dua11ly's Avatar
Dua11ly
Bad Starting 95 PSD
Engine starts ok when cold but soon as it gets warm 10-15 mins it will not start again it just cranks over rearly fast. If i let it cool down it starts again first go. Any ideas. I've changed the oil and filter, Also the fuel filter but this has made no change.
Thanks Andy
Old Feb 28, 2006 | 12:10 PM
GarryR's Avatar
GarryR
Could be IPR "O" rings. when the truck cools down the oil viscosity is greater allowing less oil to bypass. There is a write up regarding making a socket to remove the unit. It may also be the injector O rings. How did the fuel filter look when you changed it? If it was black and oily this would point to injector O rings.I believe the oil pressure needs to be somewhere around 500? psi to fire the injectors. I read this somewhere but I understand the memory is the second thing to go. Someone else will chime in i'm sure.
Found this link on another site
http://cw-diesel.com/LuxSite/IPRInfo.htm
Old Mar 1, 2006 | 04:21 PM
Dua11ly's Avatar
Dua11ly
THANKS for the link GarryR the fuel filter was ok so looks like i will be checking the IPR this weekend. If that checks out any other idea's i could check while i'm in there?
Andy v
Testing.....
Apr 28, 2013 08:10 PM
jeep802001
Dec 26, 2012 08:34 PM
360andy
Jun 24, 2012 06:03 PM
Incom_98
Nov 17, 2011 08:01 PM
Mil1ion
Apr 6, 2002 07:49 PM
