do compression check on that cyl, replaced ign wire? heard one guy had a rocker arm nut that vibrated off, he'd thought it was a valve cause he had no compression
Compression on that cylinder is 150 psi. I checked it today. Could that ignition wire be bad even though it has spark? I am checking fuel pressure tomorrw.
