The speedometer is also used to provide a speed signal for correct operation of the vehicle's powertrain control module (PCM) (12A650), electronic transmission and speed control (if so equipped). Because of this, it is VERY IMPORTANT to change the internal conversion constant of the speedometer if the size of tires, or the rear axle and ring gear on the vehicle are changed. Changing the conversion constant to the proper value when the tires, or the rear axle and ring gear are changed will also make sure that the speedometer retains the original factory-set accuracy. The conversion constant can only be changed six times once the vehicle leaves the factory.
