Rear End Change
Old Mar 19, 2001 | 08:13 AM
77f100's Avatar
77f100
Rear End Change
This weekend I replaced my 3.00 rear end with a 3.50 rear end. Works great, launches like a rocket. Now I have to adjust the speedometer. Any one know where to get the gears and how extensive it is to change?
Thanks
fred
Old Mar 19, 2001 | 08:41 AM
mgessner's Avatar
mgessner
Rear End Change
Tell me more! I've been wanting to do the swap for a while now. What engine/trans are you running? I have 360/C6, and it is slow off the line. It pulls hard from 30-50 in 1st, and to 90 in 2nd. I want it to pull hard from start to 60. My truck is my daily driver, so I don't want to go too far. I have been contemplating between 3.50 and 3.70 (or 3.73).
The other train of thought is that I didn't know anything when I had my engine rebuilt 10 yrs ago, and the guy may have put too much cam in it. According to what I have read here, if I rebuilt my engine to a 390 (or stroked it to a 410!), the 3.00 rear end would be just fine. Any opinions?
Old Mar 19, 2001 | 12:19 PM
jowilker's Avatar
jowilker
Rear End Change
Matt, go ahead with the 3.70 rear, just get a higher limit on your gas card, you'll need it. You should be able to get it down to about 6-8 mpg. But just think of the great fun you will be having.
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quite of night you can hear chevies rusting away.
Old Mar 19, 2001 | 06:04 PM
FE427TP's Avatar
FE427TP
Rear End Change
I have 4.11's and get 10.5mpg with a low compression 360 and a double pumper carb., so you should get 10 at least if your engine is in proper tune. As far as a proper gear for the speedo, try checking wrecking yards and U-Pull-It's for a truck with the same rearend gears as yours. Then steal the spedometer cable and put it in yours, this assumes that the gear that governs how the speedo reads is the driven gear on the spedometer cable instead of the drive gear in the transmission.
Old Mar 19, 2001 | 07:54 PM
jon_ran's Avatar
jon_ran
Rear End Change
I have a 1979 f-250 with a 300-6 and a (I think) 3.75 rear end.
I don't care so much for acceleration but would like better mpg.
Does anyone have a set of 3.0 gears they would like to sell or swap?
jon_ran(No Email Addresses In Posts!)
Old Mar 19, 2001 | 10:10 PM
jford99's Avatar
jford99
Rear End Change
Take a look at the classifieds on this site. I have a 1 ton ford single wheel with 3.00 gears. I don't know where you live but I would make you an unbeatable deal if you are anywhere near Texas.
Old Mar 19, 2001 | 10:23 PM
jowilker's Avatar
jowilker
Rear End Change
My My My, Al Gore did win Fla. and resides at 1600 Penn. ave.
John
jowilker
66F100s Rule
Old Mar 20, 2001 | 06:30 AM
77f100's Avatar
77f100
Rear End Change
I have a 300 with Offenhauser manifold, Holley 390, Comp cam 260, Ported/polished head 1.94/1.60 valves, Fisher balancer, MSD ignition, Dynomax headers. The 3.50 rear end changed the performance dramatically. I would not go any lower. It has great launching power. I problably dropped 10 mph for the same RPM so for instance if you are at 50 mph at 2000rpm you'll now be 40 mph.
I've read the other responses and I feel 3.70 would kill your gas mileage. Hope that helps
Old Mar 24, 2001 | 09:19 PM
steakman_usaf's Avatar
steakman_usaf
Rear End Change
How many horses do you think you're pumping out with that setup?
Did the balancer make a big improvement in the rev department? What is the advanced duration on that cam, and does it sound stock or like it's got something big?
Thanks alot...
Chris
1982 F100 Flareside
300 I-6 SROD 4speed
MSD6AL, 8.5mm S/C Wires
Blaster 2F Coil
Blue & Silver
Old Mar 24, 2001 | 09:21 PM
steakman_usaf
Rear End Change
Geez why did I say advanced duration? DOH!
Chris
1982 F100 Flareside
300 I-6 SROD 4speed
Blaster 2F Coil
Blue & Silver
Old Mar 24, 2001 | 10:22 PM
otto's Avatar
otto
Rear End Change
Jason302
Jul 20, 2011 07:24 PM
dustin.murdock
2009 - 2014 F150
Jul 19, 2010 04:46 PM
knash0727
Jan 5, 2008 12:21 AM
7sixf150
22
Oct 9, 2005 10:01 AM
A92Van
Aerostar
Dec 14, 2003 04:40 PM
