I have a 2005 f-250 diesel Oil seems to be dripping where the rubber boot joins the end of the turbo exhaust.My oil level has not changed . I took it back to the dealer and was told it was the oil sweat from the turbo. Is it normal for it to drip ? Help
Welcome to FordTrucks.com! We are the Internet's Premiere Resource for all things Ford Truck and SUV related!
We are happy to have you! There is a ton of great info on this site. But, before you go snooping around there are a few things you need to do first.
1) Want to meet or talk to other members in your area? There are Provincial, State and International Chapters located near the bottom of the main forum page.
2) Before you post a thread asking a question be especially aware of where (what forum) to place it in. FTE is HUGE! Make sure you read the Read First: at the top of the forum before you go posting.
Thread moved to 6.0L Power Stroke Diesel engine forum.
3) And finally you should review the Guidelines. They will kind of give you an idea of what is and isn't allowed on this site ("The Rules").
And that is it. I hope you enjoy the FTE "Experience"! This is a great place and we have lots of fun while exchanging valuable info. If you have any questions or problems do NOT hesitate to contact me. Just click my username then send me an email.
I had an oil leak after a Ford dealer replaced my injector #6. The wired thing is that the leak or (spray) of oil was on my oil filter, and hood area above the oil filter. I told my nephew (who works at different Ford dealer) about the problem and he came over that after work to check the truck and found the trubo pipe just a little loose where it returns to the intake manifold. The black plastic pipe appeared to be tight be he pushed it on a little more and cranked down the clamp super-tight and the "spray" of oil ceased. He said that the turbo does leak or spray a fine mist through the turbo system during normal operation and the residue just gets burned up in the engine. If the residue finds a way out of the pressure side of the trubo system, it will appear to be an oil leak. Hope this helps!
I frequently use a high pressure sprayer (CAREFULLY) on the engine when at room temperature and the compartment components 50% of the time I wash my truck to keep it clean. It does a great job and keeps it looking nice.
