De-fuel?
Old Feb 27, 2006 | 09:02 PM
Roamineye's Avatar
Roamineye
De-fuel?
Hey, guys - I've had my truck for better than a year and have never seen the check engine light come on. Today, I kicked it in the hiney to pass someone, and when I got around them, my CEL was on. Also, it felt like it was making only about half its normal power, and it stayed that way until I shut it down and re-started. After that, the CEL was out and power was normal. Since I put the Stage 1's on, it's pretty easy to hit 30 psi of boost, and I'm pretty sure that's what caused the CEL. Is the power loss due to what you guys refer to as "de-fueling"? I just want to make sure that this is "normal" and not something going south on me. Thanks!
Old Feb 27, 2006 | 10:12 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
It's certainly possible, but "half it's normal power" is a bit excessive for a "normal" defueling situation. Best bet would be to have the code pulled and see what it is.
Old Feb 27, 2006 | 10:14 PM
smuzz's Avatar
smuzz
I am not positive on this but I would guess you couldn't get enough oil to the Bigger Injectors so that is what made the code pop up but that would be my guess. But if this was the case I think that it would of ran fine after this. I don't know if that is the problem but it may be somewhere to look or check.
Old Feb 27, 2006 | 10:27 PM
lukecline's Avatar
lukecline
i would bet its an icp code, probably a p1211. You need to put a fresh hpop on it and the cel will go away.
luke
Old Feb 28, 2006 | 06:15 AM
Roamineye's Avatar
Roamineye
Thanks, gentlemen - I'll post the results after I have someone suck the code out for me.
Old Feb 28, 2006 | 07:37 AM
1997F-350's Avatar
1997F-350
luke
i agree i can throw one in my dads truck with split shots very easy. but usually after 30 seconds of normal driving it goes off.
i have yet to throw one in my truck yet with the stage 1's.( i havent taken my chip any higher than the 75hp setting yet....im too scared. )
Old Mar 1, 2006 | 02:40 PM
Paid to Hunt's Avatar
Paid to Hunt
Is there any difference between the HPOP in the 1996 and 1997?
DO those splitshot injectors need more oil than the ones in the 1996?
Old Mar 1, 2006 | 04:13 PM
444dieselrod's Avatar
444dieselrod
No difference in 96-97 HPOP's.
YES the Splits will take more oil your standard single.
Diesel Rod
