oil mess
Old Mar 13, 2001 | 01:12 PM
jpb222's Avatar
jpb222
oil mess
A few months ago the 302 in my 76' f-100 blew, I replaced it with
a 302 out of a 78' Ltd. The "new" engine leaks oil from the
lower front passenger's side. I tried tightening all of the
bolts on the oil pan that I could reach along with the timing
cover bolts. However when I drive hard it still leaks a
significant amount of oil. Most prominently around the dipstick
tube.
Any suggestions?
Thanks,
John
Old Mar 13, 2001 | 05:46 PM
390fe's Avatar
390fe
oil mess
A bad oil pressure sender can leak oil. Check to be sure yours doesn't leak. Also, if you changed oil recently, be sure you don't have two oil filter gaskets stuck together.
Jason Kendrick
1970 F100 Custom 390/C6
1978 F150 Ranger Lariat Supercab 460/C6
Old Mar 13, 2001 | 06:12 PM
jpb222's Avatar
jpb222
oil mess
both of those are on the other side of the engine so it isn't
either of those.
thanks anyways,
John
Old Mar 13, 2001 | 06:29 PM
Like M. Fords's Avatar
Like M. Fords
oil mess
Remove the dipstick tube; clean it up with some laquer thinner & a Q-tip (cotton swab). Dab some Ultra Blue or Ultra Copper silicone sealer around the tube and re-install it. Let it cure for at least 24 hours. It could be that this is the only leak you have; if not, fixing the ones you know will make others easier to detect. Keep in mind that that the fan will blow leaks to different areas of the engine making it seem as if they come from somewhere else.
Old Mar 25, 2001 | 05:24 PM
jpb222's Avatar
jpb222
oil mess
thanks, I'll have to try that when I get the chance.
Old Mar 25, 2001 | 07:42 PM
jkmjustin's Avatar
jkmjustin
oil mess
Have you replaced the PCV valve. If you are building pressure in the crank case that could be your problem. Also check to see if dipstick is tight into oil pan.
Old Mar 25, 2001 | 09:30 PM
jowilker's Avatar
jowilker
oil mess
ldsparamedic
Jan 19, 2014 01:10 PM
JOHNSHO
Jul 28, 2011 09:01 AM
jowilker
Sep 26, 2008 08:44 PM
John - NNY
Flathead V8 & Flathead 6
Jun 10, 2006 12:26 PM
John with beastly 302
Oil & Lubrication
Apr 29, 2003 09:33 PM
