Pulling Left
Old Feb 27, 2006 | 07:22 PM
jvc100's Avatar
jvc100
Pulling Left
Anyone had alignment problems after installing front and back Sky Jackers, add a leaf and alignment cams on the front.The machine says its aligned perfectly but its still pulling left hard. 1994 F250HD 4X4
thnx jvc
Old Feb 27, 2006 | 08:41 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The twin traction beam front axle does not like for the truck to be raised up.
It affects all the steering geometery.
If you look at the front tires from in front of the truck with the wheels pointed straight, how do the tires sit from top to bottom.
1. / \
2. \ /
Although this is exagerated in the angles it should set like number 1.
When you install higher arch or stronger springs that raise the front of the truck it will start looking like number 2 example.
Also when you look at the alignment specs it has allowable and preferred settings.
It also has specs for the distance between the axle and stop block mounted on the frame.
I have Firestone Ride Rite air bags on my front axle for when I am using my snow plow.
The last alignment I had while I still had the TTB front axle cost me close to 900 dollars, but it drove like a car. everything was set to preffered setting. We played with the air bags a little and found out that I had to run only 10 PSI in the air bags or the front end was so far out of alignment that it could not be brought back into spec.
At 10 PSI the front wheels set like / \
At 15 they set like | |
At 20 they set like \ /
Also the alignment cams move to much, the right way to align it is with the solid degree bushings. Have to remove the top ball joint and change bushings till you get it right. The bushings have numbers stamped on them to use as a reference.
Here the only place that had the different bushings was Ford.
Good luck,
PS the money I spent on the alignment was some of the best money I ever spent on the truck. It drove like a dream after that. Also I did change all the ball joints and tierod ends when I did it.
HillBillyBuddha
Mar 3, 2014 09:58 PM
firebug
Nov 18, 2008 10:26 AM
rkane
Jun 9, 2006 10:11 PM
jvc100
Nov 1, 2004 08:21 PM
