I have a 75 f100 4x4. I just bought it and it didn't have a rear drive shaft. The person has been driving it just on the front wheel drive (well at least the transfer case works). Should this cause any immediate problems? and What years would have the same drive shaft? It has a 400ci in it.
Thanks
In the land of the blind, the man with one eye is king.
I second the motion to watch your U-joint dimensions. I swapped the rear end out of my 76 F100 to my 79 and found that I had to swap the pinion yokes because the U-joint size was different. My trucks are all 2wd.
I know on my 2wd the yoke can slide in and out an inch or so. But on this 4x4, the rear driveshaft goes from the ujoint on the rear to the u-joint off of the transfer case. Is the driveshaft a solid piece, or how does the driveshaft "float", in case I hit a huge pothole, what does the rear driveshaft do?
If you run into u-joint/yoke compatibility, you should be able to go to napa and they can get a u-joint to fit by looking in their spicer book. I used a slip joint assembly off a 75 bronco on my front 1980 driveshaft. The cups were the same but the 80 had a wider spacing. They had a stock u-joint that fit perfect with narrow spacing in one direction and wide spacing in the other. I also adapted a driveshaft to a stock 53 pickup rear and besides different spacing this one needed different cup sizes and they had one to fit this too.
