General Automotive Discussion
It's only a Scratch.
Old Feb 27, 2006 | 01:19 PM
IBeam's Avatar
IBeam
Talking It's only a Scratch.
Got a scratch on my truck today, think someone can fix it for me.
Ok, so maybe it is a dent or two.
Well maybe a little Bondo.
Well, mayge a lot of Bondo.
Ok, the truth. This is what is left of a F250 Crew Cab after a 190 Ton Haul Truck runs over it. No one was hurt in this accident, but it shows you how dangerious it can be at times. This was from a Gold mine in Nevada.
My Son is a Welder at Kennicott Copper Mines, and works around these trucks all day. He drives one just like it, and he rebuilds the Buckets on the Shovels that load the Haul Trucks.
After seeing this, I am worried about him.
Old Feb 27, 2006 | 01:26 PM
wlihntr's Avatar
wlihntr
i was thinking maybe a tank drove over it....wow
Old Feb 27, 2006 | 01:54 PM
sierraben's Avatar
sierraben
A quote from Jeff Spicoli (Fast Times at Ridgemont High)
"Relax, alright? My old man is a television repairman, he's got this ultimate set of tools. I can fix it."
Old Feb 27, 2006 | 02:04 PM
IBeam's Avatar
IBeam
Maybe that is where Tim the Tool Man Taylor got it. HO- HO- More Power.
It may sound odd, but the first thing I thought of when I seen it was if it mashed the Transfer Case and Trans, or drove them into the ground. I think it mashed them. If you look at the first picture, as flat as it is, the frame is flattened out as well. The entire thickness cant be more then 5 inches.
Old Feb 27, 2006 | 02:40 PM
1FineBroncoBabe's Avatar
1FineBroncoBabe
Geez... That's how I felt on Sunday morning after several drinks the night before .
Hoping everyone walked away unscathed.
Old Feb 27, 2006 | 02:46 PM
Bronco2Nic's Avatar
Bronco2Nic
That'll buff out.
Old Feb 27, 2006 | 02:48 PM
LilDuke's Avatar
LilDuke
You see a crushed truck, I see a couple good tires, tailgate, tailight, maybe an axle?
Old Feb 27, 2006 | 03:41 PM
jake00's Avatar
jake00
wow, haul truck get away? or the guy park in a "loading zone"?
Old Feb 27, 2006 | 04:07 PM
rbohm's Avatar
rbohm
a little rubbing compound, some polishing compound, and some elbow grease and that will be good as new.
Old Feb 27, 2006 | 04:24 PM
jb's94f-250's Avatar
jb's94f-250
can always build it better ..stronger and faster < seems alittle slow now tho
Old Feb 27, 2006 | 04:38 PM
rebocardo's Avatar
rebocardo
As for your son, if I see a 190 ton truck coming at me going 3 mph, I think I am going to run the other way. Most trucks do not have that option, or at least not this one
Old Feb 27, 2006 | 04:42 PM
JD717's Avatar
JD717
oh thats supposed to be like that, that'll bufff out, thats factory error, thats SUPPOSED to be on fire. from Homer Simpson after hitting Her Majesty of England's royal coach.
Old Feb 27, 2006 | 05:20 PM
Dungeon_Master's Avatar
Dungeon_Master
Now that's a good easy weekend restoration project. a little touch up paint and a tune up and it would be brand new.
It might be a good idea for the mine bosses to put a picture of this in every vehical in the yard for warning. With a note attached stating
If you think you can handle a little fender bender with the big boys think again!
Think before you park it and walk away!
Old Feb 27, 2006 | 05:21 PM
Chugalug's Avatar
Chugalug
Should be worth more to the salvage yard, they won't have to pay to have it crushed.
Old Feb 27, 2006 | 07:17 PM
Greywolf's Avatar
Greywolf
Put up a sign at ground zero (the heaviest trafficked area) that says:
"GM AND DODGE PARKING ONLY!"
Then stand back and watch the fun...
"Never tell a Kodiak 'Leggo my Eggo'..."
